Before & After
Old May 17, 2007 | 03:29 PM
ToxicZ's Avatar
Before & After
Clean up that engine bay! 12,000 less vacuum hoses, a shiny rail and a bit of buffing and the 280zx head and manifold can actually be seen with the naked eye.
Before:
After:
Old May 17, 2007 | 03:45 PM
Nice! But will it still run / pass emissions with all that gone...
Old May 17, 2007 | 07:16 PM
n00blar's Avatar
Wow, interesting...
Isn't there a sticky that shows how to remove some of these hoses?
I'd be interested in doing that once I finish fine tuning my ZX.
Old May 18, 2007 | 06:46 AM
get an electric fan, really cleans things up.
Old May 18, 2007 | 07:54 AM
007max's Avatar
From NY to AZ
I think that if you use black zip ties instead of those lime green ones it would look at least 2x better.
lol
Old May 18, 2007 | 08:00 AM
so how do you adjust your idle now?
Do you have to hold the throttle down a little until the engine warms up just to keep it running?
Looks much better though!
Old May 18, 2007 | 10:51 AM
duowing's Avatar
NisTuner
I like the motion blur effect that the first before picture has on it. It makes it more dramatic. But it looks cool. I'd like to do that to my turbo, so then that way it's a lot easier to redo vacuum lines, as well as find vacuum leaks, plus it just looks better.
Old May 18, 2007 | 06:23 PM
ToxicZ's Avatar
Actually, if it wasn't for my vacuum leak, it would run fine on startup without manually gas pedalling it. I have the idle speed bumped up a bit on the TB.
Electric fan would be good indeed. Will perform that swap soon enough. And I will be using green zip ties to hold it on.
