Another stupid question
Old Mar 8, 2007 | 08:31 PM
antiman's Avatar
when i open my hatch from inside the car the cable does not release enough to close the hatch back, any quick fix or replace the whole cable? Since my interior is 100% custom getting to it will take a lil work
Old Mar 8, 2007 | 08:35 PM
Check the cable tension... tighten / loosen if necessary (by adjusting the length of the cable at the latch). Also grease it a lil if dry.
Old Mar 14, 2007 | 08:29 PM
BigEkak1941's Avatar
Poss Rust on Cable
When you open the hatch check the latch to see if is sliding properly. You may need to lubercate both it and the cable (moisture gets into the cable and it will stick). Hopefully that will do the trick. Good Luck
bigge_313
Apr 26, 2006 08:16 AM
SurgeNJ
May 21, 2004 08:24 AM
drivernumber22
Mar 9, 2004 04:54 PM
CarlHill
Sep 3, 2003 02:04 PM
Togish1
Oct 10, 2002 07:11 PM
