Adjusting Gas Pedal?
Old Jun 18, 2006 | 03:56 PM
3XAZOWNER's Avatar
I am green when it comes to this topic, so bear with me.I searched under gas pedal adjustment but had not luck.My gas pedal has only about a 2-3 inch travel from starting point to the firewall. When my pedal is pressed all the way, I still have more pedal play under the hood (like if i was revving it up under the hood, which may be the throttle linkage.) My repair manual says like 5 inches of pedal. Shouldn't I have more pedal play and how do i adjust the pedal to get the pedal more off the floor? or where do I adjust it? The only other thing i know to do is cut the carpet out from under the pedal (HA HA).
Old Jun 18, 2006 | 05:43 PM
nismo619's Avatar
i can tell u one of two things, first off take off the drivers side panel.. take off the black air duck.. u will have to get onto your back and look for your gas petal at the very top of your gas petal there will be a small screw 8mm i do belive.. u will have to " retard it " loosen it to give u what u are looken for...
omniserv
Apr 9, 2011 04:24 PM
Mrmoose
Nov 1, 2010 10:34 PM
FranksZ31's
Feb 5, 2006 05:28 AM
dylokjai
Jul 28, 2005 04:00 AM
n_2_fairladyz
Dec 17, 2004 02:18 AM
