ZDriver.com
-   280ZX (S130) Forums (https://www.zdriver.com/forums/280zx-s130-forums-77/)
-   -   Accessory Relay? (https://www.zdriver.com/forums/280zx-s130-forums-77/accessory-relay-32026/)
BackHouseZ Feb 14, 2011 02:31 PM
Accessory Relay?
If Anybody knows what the Accessory Relay controls please tell me?
NismoPick Feb 14, 2011 02:33 PM
I'm going to take a stab in the dark and say it controls the accessories. :D
BackHouseZ Feb 14, 2011 02:47 PM
i'm just curious which ones. my dome lights dont work nor does my power mirrors.
icice9 Feb 14, 2011 03:07 PM
when your turn your ignition to ACC... everything that turns on im guessin.. like the radio. cig lighter etc...
NismoPick Feb 14, 2011 04:08 PM
Have you checked the fuses?
All relay and wiring schematics are found in the downloadable FSM here: www.xenons130.com/reference
BackHouseZ Feb 15, 2011 08:04 PM
I checked fuse. The Service Manual says its the first one from the top on the left side. Should be rated at 10A. Also I checked fusible links
WildmaN Feb 15, 2011 08:20 PM
Try your lighting relay. (room lamp timer) On my n/a, it is located on the driver side kick panel area. My dome light didn't work, and I changed out the relay, and it worked after that. Also I replaced the door lock timer relay also. And my power locks worked again.
BackHouseZ Feb 15, 2011 08:57 PM
i will look into that..
My door lock only unlocks, lock does not work?
