acceleration issues
Old Sep 11, 2009 | 04:01 PM
TheGrimaceTab's Avatar
acceleration issues
my 79 280zx sputters slightly and is hesitant in low rpms. im thinking cleaning the egr, but one of the bolts is in a wierd place cant get at it will have to get like a u joint socket. do you guys think this is the problem or ne thing else i should be thinking about?
Old Sep 11, 2009 | 04:42 PM
skib's Avatar
This facepalm's for you!
dose it do it when its warm or cold?
Old Sep 11, 2009 | 04:47 PM
njgheewala's Avatar
Dunkin' Donutz
Maybe you can find your solution and more detail to the problem in here:
https://www.zdriver.com/forums/280zx-s130-forums-77/small-acceleration-problem-29184/
Old Sep 11, 2009 | 04:52 PM
basically does it all the time.... that post does not really apply to me mine idles good, and high rpms good. but sometimes sputters in low rpm in all gears
Old Sep 11, 2009 | 08:13 PM
FubarI33t's Avatar
AFM, or bad dissy cap/rotor
Old Sep 11, 2009 | 09:07 PM
audiofreak97's Avatar
Oh yeah?! Freak this!!!
I would have to agree with the distributor or cap and rotor for the sputtering.
And I would suggest investing in a good set of those ratcheting box-end wrenches. Makes for working on things a lot easier when ratchets won't fit. I use mine all the time when I work on the Z.
Old Sep 12, 2009 | 12:06 PM
how would i test the distributor to see if this is the problem. i will do my egr first and see if this problem gets any better if not ill see about distributor
Old Sep 12, 2009 | 07:47 PM
FubarI33t's Avatar
wow. EGR. i don't have that........
Old Sep 13, 2009 | 01:19 AM
njgheewala's Avatar
Dunkin' Donutz
Just remove the cap and rotors and visually inspect them, if you see carbon build up or corrosion on the metal parts of the cap and rotor change. If it still did not fix the problem then go for the big stuff like AFM! Oh yeah, you can also check the conditions of the spark plug wires and the plug sit self sometimes small problems can seem like huge problems...
How does that sound?
Old Sep 13, 2009 | 03:30 AM
pull your cap/rotor and if you see residue or anything built up on the contact, clean/scrap it off. Also might wanna try checking out your throttle position sensor.
vanboy
Apr 1, 2015 04:59 AM
TapTap
Sep 22, 2012 10:26 PM
ksloan25
Jun 1, 2010 11:02 PM
drftrzx
Oct 8, 2008 09:07 AM
pconno4
May 2, 2006 06:16 PM
