83 power steering
Old Mar 13, 2009 | 04:48 PM
hchase17's Avatar
83 power steering
Would an 83 2+2 be too hard to drive with the power steering removed? I know it would make a big difference but how much? Does anyone have experience with this?
Old Mar 13, 2009 | 05:11 PM
jverz's Avatar
If you're just taking the belt off the pump yeah it'll be a bitch. It's not like driving a car that never had power steering.
Old Mar 13, 2009 | 05:16 PM
scorpionp54's Avatar
easiest way to find out would be to take the belt off, i did on my 82 and it would take some getting used to, i put the belt back on.
Old Mar 13, 2009 | 05:20 PM
jverz's Avatar
You gotta remove the entire power steering system, just taking the belt off doesn't tell you anything.
Old Mar 13, 2009 | 05:21 PM
oh didn't realize he wanted to put in a manual steering rack in
Old Mar 13, 2009 | 05:22 PM
jverz's Avatar
that's the only way to do it, or you'll end up putting the belt back on like you did
Old Mar 13, 2009 | 05:26 PM
ya and the only reason i had the belt off was because autozone gave me the wrong size
Old Mar 13, 2009 | 05:28 PM
jverz's Avatar
lol aye that'll happen.
Old Mar 13, 2009 | 05:54 PM
hchase17's Avatar
just another question on the steering system. is replacing the rack and pinion extremely difficult on these cars?
Old Mar 13, 2009 | 05:55 PM
If converting to manual rack... not very (as long as you know what you are doing).
Old Mar 13, 2009 | 05:59 PM
hchase17's Avatar
well i was contemplating taking the power steering off b/c of a leak and to save jus a lil bit of weight i know it isnt much but i was talking about the actual ps rack and pinion cuz its got a lot of play in the wheel turning to the left
Old Mar 13, 2009 | 06:02 PM
You'd lose a grand total of prolly 6 to 7 lbs... not enough to make up for nightmare turns below 10mph (keeping the stock rack). Is the leak coming from a hose? Connection? Reservoir? Rack? Boots?
Have you checked the ball joints?
Old Mar 13, 2009 | 06:08 PM
hchase17's Avatar
its a hose in a couple places...i actually took the belt off of a nissan p/u i had with 31s o nit and i drove that for a couple months and it was pretty tough i jus didnt know if it would be as bad since the tires are way smaller
Old Mar 13, 2009 | 06:34 PM
just replace the how its easy. you can even try some stop leak, it works if its a small leak usually. but i would do something fast cause if you keep runing the pump out of fluid or low on fluid it will die
Old Mar 13, 2009 | 06:40 PM
hchase17's Avatar
its not that bad yet its a slow leak and plus it isnt even on the road yet
jurickwessels
Mar 29, 2012 02:46 PM
domsgarage
13
Mar 19, 2010 10:26 PM
shall345
Jan 4, 2004 03:10 PM
Z kWick
Dec 24, 2003 10:36 AM
Bracem
Apr 4, 2001 04:29 PM
