'83 280ZX - Finding Front Tension Rod Bushings
I snapped my front passenger tension rod a few weeks ago, and am trying to find rubber bushings since many posts out there have suggested that the poly bushings are what caused the failure on my car. I found these for $40...
https://www.ebay.com/itm/Datsun-OEM-...4383.l4275.c10 That seems awfully expensive to me. RockAuto has strut rod bushings: https://www.rockauto.com/en/moreinfo...0596&jsn=10596 ZCarDepot has rubber tension compression strut rod bushings: https://zcardepot.com/front-strut-ro...shing-set.html I feel confident that I'd be fine buying any of these, as I think they're the same thing, can anyone weigh in on the tc rod bushing vs strut rod bushing vs tc strut rod bushing terminology? Can you use bushings from a 240/60/80Z, or stick with 280ZX? |
Yes those are all same thing. Apparently if you use one rubber, one poly (on the same rod) it will not snap. I use one rubber one poly, but not sure if earlier Z cars had the same issue, so far so good either way.
Originally Posted by Skully
(Post 347611)
So for the poly I went to the side that takes the load on the braking, which is the front facing in a Z, I think in a ZX its the opposite. The back side takes most of the braking force grunt (someone correct me if I'm wrong its been a while since ive been under a ZX). To be honest I am sure rubber would have been fine for a daily driver/street car.
