82 280zx Hood
Old Apr 11, 2012 | 11:34 AM
Trolloc's Avatar
82 280zx Hood
Quick question on the hood for the 82 280zx turbo the NA hoods from 79-83 will also bolt right up correct? and do you know if the earlier hoods will bolt up im having trouble finding a hood around me thats turbo and isnt rusted but im putting a FMIC so the non turbo hood is fine as long as it bolts up.
Thanks in advance
Old Apr 11, 2012 | 11:38 AM
Welcome to ZDriver!
Yep, all hoods from 79-83 have the same bolt pattern / attachment mechanism. The only differences are (as you stated) the 79-81 vs 81T & 82-83 vents.
Old Apr 11, 2012 | 04:32 PM
The turbo hood actually significantly increases air flow to the area around the turbo especially when the car is moving. The shield beside the brake booster is part of the ducting to bring cool air down to that area greatly reducing the engine bay temps. If you are wrapping your header, turbo and downpipe that will also reduce engine bay temps significantly so the NACA ducting isn't as crucial...
Old Apr 13, 2012 | 02:55 PM
Trolloc's Avatar
Found a hood off a 80 2+2 for $50 with minor rush but the hood "scoop" area in the center is pretty dented to hell was thinking of putting a cowl induction scoop in that area any recommendations on height and style? not wanting anything huge thinking maybe 2" or 2.5" tall never looked at any hood scoops so not sure what to look for.
Old Apr 13, 2012 | 03:30 PM
This is a reproduction Datsun made to address the vapour lock issues it had with the Hitachi carbs on the 260Z IIRC.
I think if you cut your stock hood at the stock buldge and modified it to a similar cowl it would look pretty hot..
Old Apr 13, 2012 | 04:31 PM
WanganDevilZ's Avatar
The Emblem Thief y0!
I'm honestly in the market for a hood with zero cowl on it, or vents
Imagine a world, where you didn't have to use two cans of PB Blaster to get the intake manifold bolts off because of rain coming in through the turbo scoop...
Rustin de' crap out of everything in it's wake.
Guess should keep Z garaged from now on.
Old Apr 13, 2012 | 05:54 PM
You're gonna get rust there anyhow - it's more a condensation issue than rain...
Simple fix - high temp anti-sieze...
Old Apr 13, 2012 | 06:22 PM
Lesnocker's Avatar
If you value the car It pretty much needs garaged. How ever if your garage is wet at all its better to keep it out. . . . Went to see a garage kept z for sale and well the wet garage did damage much worse then zs sitting in the woods. . . . And the manifolds well not much you can do . . . . Myself I save all manifold work for the next engine pull then I replace everything with new. . . . . Got about 2 to 3 years of easy wrenching before things seize up
Old Apr 14, 2012 | 06:35 AM
Trolloc's Avatar
That is pretty cool wasnt really wanting to spend 250 right now but that is an option
Old Apr 14, 2012 | 12:05 PM
It's for the S30 chassis not the S130 (280ZX). You should take your junky hood and cut it out along the stock lines pop it up and see what it looks like. A little fiber glass and resin and you could make your own and make it look pretty decent for not a lot of $$...
aruiz714
Jun 6, 2013 10:27 PM
WildmaN
Apr 5, 2011 12:28 PM
BigEkak1941
Jun 30, 2007 01:56 PM
duowing
Sep 20, 2005 11:23 AM
