81 280zx speedometer issues
I pulled out the dash from my 81 280zx with intent to replace the dash lights and speakers as well as reupholstering it as well part of my restoration process. And after removing it I noticed the speedometer end is loose and has no control and seems to just wobble around. I took out the plastic protector to try and see if I could figure out as to why this was like this but was no use and then that's when I noticed something fell out from somewhere from instrument panel a little rubber block slightly warped on one side and I have no clue as to where it came from. If anyone could help me that's would be greatly appreciated!
be more careful when you start tinkering. take digital pics as you disassemble things.
Welcome to ZDriver!
Originally Posted by Luke_elkins32
(Post 345148)
(Post 345151)
Welcome to ZDriver!
The rubber block is a wedge to hold the gauge cluster in place. There are two and are placed at the left and right bottom of the cluster at the metal dash frame. |
(Post 345148)
Nobody but you can inspect it... just spin the back of the speedo to see if it still reads. Not complicated. :)
