79 280ZX to turbo
Old May 29, 2002 | 02:34 PM
Skully's Avatar
Re: 79 280ZX to turbo
thats what i wanna do to my 81 280zx but like you i have no idea if this would be good....
just like you i wanna take a turbo of a turbo Z and put it on my stock NA
wooohooo done done finaly done
Old May 31, 2002 | 11:45 AM
There is a reason why the turbo motor has less compression. That reason is (for some unknown reason) the lower compression allows you to more easily force more boost in there. The higher compression of your N/A motor will resist the forced induction, requiring you to spend more money on a larger turbo just to put the same boost that a lower compression engine allows.
low compression / high boost
high compression / low boost
that's just the way it is...
Also, the turbo block is the same but the pistons have thicker rings on them. The head has larger exhaust ports for the added flow of gasses the turbo makes. You NEED to use the entire turbo engine if you want it to run good and run fast. Don't mess around with bolting on a turbo exhaust manifold.
Take the whole engine and wiring harness (and gauges) and put it in your Z, or just buy the 280ZX turbo and put your nice body panels and interrior on the turbo Z. :-)
Old May 31, 2002 | 02:52 PM
zguy36's Avatar
Dead
The reason that you can run more boost with a lower compression ratio is due to cylinder pressure. At a certain pressure inside of the cylinder on the compression stroke, you are going to experience detonation. By lowering the compression ratio, you can add more air, via a turbocharger and still keep the cylinder pressure below the detonation point. Make sense?
-jeremy-
Old Jun 2, 2002 | 09:57 AM
Skully's Avatar
ok man thx alot
Old Jun 23, 2002 | 10:14 AM
Skully's Avatar
ok i found a 300zx engine and its a turbo so if i was to take the turbo off and strap it to my 280zx and then get the right compression would it work?
which turbo is better 280zxt or 300zxt (aprx 84-6)
i know it would b better off to go with the engine but its too much money for me to go with the whole engine
koprutzxt
Aug 2, 2012 11:55 AM
DUBAUDIO
Feb 1, 2012 07:47 PM
benny127
Sep 13, 2010 12:13 PM
280ZX_AV8R
Sep 30, 2005 02:37 PM
JustinToxicated
Dec 16, 2003 07:36 AM
