454 in 280zx?
Old Aug 20, 2008 | 10:19 PM
michanic220's Avatar
454 in 280zx?
how much would i have to modify my stock 280zx engine bay to make a 454 fit in the bay? it looks like it has plenty of room for a 350 long block.. the 454 long block cant be much bigger i assume? i've seen it done i just wanna know what im getting myself into before i do somthing like this.
from what you guys have told me i have rack and pinion steering.
Old Aug 20, 2008 | 10:30 PM
all custom mounts radiator and driveshaft and a little re-wiring assuming your going carb's
Old Aug 20, 2008 | 10:43 PM
yes, with this L28E im deffinatly done with EFI! lol.
wouldnt i have to change out the springs on the front suspension to handle the weight? it says a stock 454 with iron blocks and intake weighs in at 650, if you change the heads and intake to aluminum it takes 90 pounds off of that. so i get 560 pounds.. would i have to upgrade for that?
but other then that i wouldnt have to make any body changes to fit the engine?
Old Aug 20, 2008 | 11:24 PM
maybe a little, the stock L motor aint all that heavy, def isnt light though. but springs, is not a hard thing to do at all. i doubt you;ll have fitment issues the engine bays on these cars is pretty big. might have some trouble with powersteering though might have to do some craftsmanship.
Old Aug 21, 2008 | 06:12 AM
K Cuv's Avatar
why a 454? why not go LS1? its smaller, much lighter, cheaper, easier to maintain, newer, more reliable, EASY to make crazy fast, and its been done before so you can probably find some good write ups!
Old Aug 21, 2008 | 06:23 AM
^^^ He said he's done w/ EFI... even though EFI has much more potential.
Old Aug 21, 2008 | 06:26 AM
K Cuv's Avatar
yea i missed that sry - but dealiing with a 30 year old datsun motor vs. a less than 10 year old corvette motor is a diff ballgame. i personally would be way happier with the LS1, just my opinion.
Old Aug 21, 2008 | 06:27 AM
I agree 10000000000000%.
Old Aug 21, 2008 | 06:51 AM
dont bother with the 454, your gonna have to rip out the fender wells and maybe change to mustang 2 front suspension to make it fit nice. the dang 350 is shoe horned. the 454 is wider yet, and the frame rails arent
Old Aug 21, 2008 | 01:22 PM
well still you could never get the torque from a LS1 that you could from a 454 (part for part)
and im not really a fan of the vettes unless its a older stingray.
everyone around here is bolt on this, bolt on that.
and i've always been one to be different, so i want a powerful engine without bolt on parts.
Old Aug 21, 2008 | 01:23 PM
i dont know, i can get a 350 for 250-300$$, or a 454 big block for 550-600$$
either engine i go with is going to be torn down and rebuilt so mileage doesnt really matter.
Old Aug 21, 2008 | 01:56 PM
Welp... apparently you know something everyone else doesn't... so get to it! Let us know how it goes.
Old Aug 21, 2008 | 02:00 PM
PS... here's your Chevy V8 hp / torque ratings. Not really much torque for all the work and $$$ you're going to spend.... unless you plan on towing a cattle trailer or mobile home behind your Z.
EDIT... peak hp is at 3600rpm... that's about grandpa speed right there.
Old Aug 21, 2008 | 02:30 PM
i never said it was going to be bolted to a low-geared 4wd tranny brah'.
the 454 is rated at 240HP and 400 foot pounds of torque. unsure of the 350 tho. havent looked.
Old Aug 21, 2008 | 03:29 PM
a Chevy 350 has 165hp??? wow! toss out that 170hp L28 quick!
Old Aug 21, 2008 | 04:07 PM
did you read that? the 454 makes a woping 210hp LOL LOL LOL LOL!!!!! OMGZ!!! so much power! there is no replacement for displacement. hahahaha... it does do 330ft/lbs though neato! if you need to tow ****
Old Aug 21, 2008 | 09:15 PM
whats the L28E engine top out in horse power? someone on here said 300?
whats the chevy 350 top out in horse power?
just trying to learn somthing new =]
Old Aug 21, 2008 | 10:16 PM
According to internet sources... the LS1 was rated @ 305-350hp / 335-375 ft/lbs torque. The 454 was rated @ 205hp / 335 ft/lbs torque. If I did my math right (and I'd like to think I did), sounds to me like the LS1 has much more potential.
+$1k to $3k to make it work in your car.
All of my previous posts about hp would probably be flywheel hp... gearing is gearing...
So are you going for the cheapest way to get hp? Just throw in a 200 shot of Nitrous and you're set!
Old Aug 21, 2008 | 11:17 PM
top out in hp? no one has built a crazy bad L28 yet 300 NA is topped out if you build right, turbo ive seen 600hp. but like i said, it wasnt a crazy build
Old Aug 22, 2008 | 12:31 AM
lww's Avatar
lww
Head Muckraker
Trying to pin TOP HP numbers on ANY engine build is an exercise in futility as every build has numerous compromises in order to achieve a specific goal. If you built an L series motor for "maximum" HP with no regard for any other element, it would be a VERY high number. This goes for a Chevy, Ford or Chrysler motor whether it's a small block, big block, LSx, etc.
The most "useable" HP I've seen in a turbo L6 series Z car was 600whp.
The most "useable" HP I've seen in a non-turbo L6 series Z car was just under 300 whp.
Old Aug 22, 2008 | 05:32 AM
Edz280zx's Avatar
Good luck fitting the LS1 into an s130 engine bay. Me and my buddy test fit one into his car and had less than an inch of clearance between the driver's side head and the gear box, that was without the manifold(or header) on. I don't know how it would be on a rack and pinion car, but it doesn't look like it would be much better. I think this swap would require some tube chassis mods to get it to fit. Just my 2 cents.
Old Aug 22, 2008 | 07:33 AM
well, i can look on craigslist but i dout i can find a LS1 under 2K.
Old Aug 22, 2008 | 07:34 AM
nope, cant find one... altho there are a set of nice heads for $250 for a LS1.
Old Aug 22, 2008 | 07:37 AM
i dont see anything wrong with this "175 hp 350 small block" guys
http://daytona.craigslist.org/pts/771771634.html
Old Aug 22, 2008 | 07:55 AM
^^^ Go for it.
