ZDriver.com
-   280ZX (S130) Forums (https://www.zdriver.com/forums/280zx-s130-forums-77/)
-   -   280ZXT Engine Cylinder 2 & 3 Not Firing (https://www.zdriver.com/forums/280zx-s130-forums-77/280zxt-engine-cylinder-2-3-not-firing-36252/)
Z_lover Oct 3, 2012 06:48 PM
Okay, so my Z was running fine except for the fact that the injectors were leaking fuel. I replaced all the injectors along with the seals. Now cylinder 2 & 3 are not firing. I placed a voltmeter at the injector connectors and it measures 0.3V (same as the other cylinders). There is spark at both cylinders and compression is good. I checked the dropping resistors for the injectors and they are all at 6 ohms. Any other thoughts on what to investigate?
Z_lover Oct 9, 2012 10:29 AM
Anyone out there??:006:
NismoPick Oct 9, 2012 10:51 AM
Did you pull those plugs to see if they are wet or dry? Maybe the injectors still aren't spraying?
Are the replacement injectors new?
Z_lover Oct 9, 2012 11:20 AM
All of the replacement injectors are new. I will have to double check if the plugs were wet or not. I suspect the same thing, but how else can I confirm they are working "electrically" speaking? I ohmed them out and they are within spec. I measured the dropping resistor voltage and I measure voltage across the harness going into the injector. Am I missing something?
Z_lover Oct 17, 2012 10:27 AM
Figured it out. Had a bad electrical connection to the two injectors, but on top of that I one bad injector (one of the new replacement injectors....grrr!).
