280zx '82 starts but won't run
My 280zx will start up fine, but it won't run unless you keep cranking it. Fuel pump pressure is OK. Once you get it running it pretty much runs OK. If I park it on an incline it dies though.
Welcome to ZDriver! Check all the basics:
Timing AFM, CHTS, and ECU connections Cold start valve Air regulator Vacuum leaks (such as loose hoses) -Buy a Haynes manual if you haven't yet. |
definately chekc your timing and vacuum hoses. can you smell any irregular smells? i don't know much but lately i've had to trouble shoot the crap out of my stock '81...
