ZDriver.com
-   280ZX (S130) Forums (https://www.zdriver.com/forums/280zx-s130-forums-77/)
-   -   2.5k ohm resistor? (https://www.zdriver.com/forums/280zx-s130-forums-77/2-5k-ohm-resistor-25035/)
duowing Feb 19, 2008 04:15 PM
2.5k ohm resistor?
I've seen in the Haynes for the 280ZX and at points in the FSM for the Z31, for testing things like throttle position sensor, adjusting CO%, etc. They show for example to unplug the CHTS and put a 2.5k ohm resistor onto the connector so it's feeding the ECU a constant signal to adjust the idle mixture by. What are these called, and can I get them at the auto parts store? Would I just look for a resistor?
KasbeKZ Feb 19, 2008 04:38 PM
it's called a 2.5K ohm resistor at radio shack. they usually have a huge wall of them. should be less then a dollar if you can get just one
duowing Feb 19, 2008 04:40 PM
cool, thanks for the info. I'm gonna have to pick up one.
SpeciallySpiked Feb 19, 2008 05:46 PM
if they don't have just one of that exact number. Put 'em in series! Yay for physics
duowing Feb 20, 2008 10:23 AM
What do you mean by put them in a series? Like you'd connect a lower value resistor to another resistor, then to the harness to make 2.5k ohms?
SpeciallySpiked Feb 20, 2008 04:07 PM
Exactly.
http://www.dkimages.com/discover/pre...6/50511730.JPG
Hard to see but there are two in series there. Most likely the resistors you find at Radio Shack will look very similar.
Resistors in series just add together.
1.5K (ohms) + 1k (ohms) = 2.5K (ohms)
