1983 Turbo Dist. to 1981 Turbo
A Happy New Year to all. I have a question for the experts here. I am planning on switching the Distributor from an '83 Turbo to an '81 Turbo. I know their is a Post on ZDriver about doing this but will the '81 Turbo ECU recognise the '83 Turbo Distributor. Thanks.
Yes indeed.
See: https://www.zdriver.com/forums/280zx...-timing-40948/
*Note: The 81 280ZX Turbo distributor does not have an internal CAS, using instead a plate attached to the back of the crank pulley and magnetic sensor mounted on the A/C bracket. Both output the same signal, but the advantage to the 82-83T optical CAS is ease of changing the encoder disc for various EFI setups, and ease of timing adjustment.
