1982 280ZX Non Turbo - Dash Sensor yellow light On
As indicated in the title, what could be the root cause of the problem? How it can be fixed?
Remove gauge cluster, remove the light bulb for the light, reinstall. Problem solved...
1 Attachment(s)
Originally Posted by hoov100
(Post 305125)
The correct / super easy way (found in the FSM): Attachment 18075 Also moved to S130 280ZX section. |
(Post 305129)
Well... that's one way (the wrong / hard way).
The correct / super easy way (found in the FSM): http://i60.photobucket.com/albums/h8...0O2Warning.jpg Also moved to S130 280ZX section. Thanks for your fast response! :023: |
remove passger knee panel. Look up to the right. There is a green and green/yellow wire plugged together. Un plug them.
