New owner of a 280ZX
Old 10-06-2015, 12:09 PM
beagler's Avatar
Howdy. New to the forum and new to the 280Z world.
I've just recently acquired 1982 280Z that's been sitting in a barn for the last 5-8yrs. I've got it started, albeit it idles very rough, but that's another issue.
Right now, my concern is the clutch is not working. When you press the pedal to the floor, there is no hydraulic back feed at all. I've pulled the master cylinder and the push rod has 100% free play, act's like it's not even connected to anything inside the cylinder housing.
My question is, how is this thing suppose to work?
Also, I did make sure it was full of fluid b/f I pulled the cylinder, it made no difference.
Thanks & pic's to follow!
beagler is offline
Old 10-07-2015, 06:59 AM
LegacyZ's Avatar
Only hydraulic clutch I've ever worked on was on a motorcycle, but I would think the principles should be the same.. if you pulled the pushrod and weren't suddenly scrambling to clean up fluid, you've got a plug somewhere not allowing the fluid to function the way it should..
LegacyZ is offline
Old 10-07-2015, 11:11 AM
beagler's Avatar
Ya, I just ordered a new one today. For $20 it's not even worth rebuilding the one I got.
beagler is offline
Old 10-07-2015, 12:35 PM
Grumpy & Helpful
rogerz's Avatar
if you understand how a brake system works then the clutch is the same. Difference is only one master and one slave. REPLACE THEM BOTH. cost is low and frustration high if you don't. If you don't understand how brakes work you should do some studying of hydraulic systems. Unlike a z31 the s130 system is very straightforward.
rogerz is offline
Old 10-12-2015, 08:28 AM
beagler's Avatar
Ok, replaced the clutch master and looks like the real problem was with the slave, so as mentioned, I'll be replacing that next.
My next problem looks like at least two of the injectors are not working. I've got spark & compression on two of the cyl but when the motor is running (rough) those two cyl do not seem to be getting any fuel.
When you remove the injector(s) can you get by with just cleaning them or do I need to replace with new?
beagler is offline
Old 10-30-2015, 02:06 AM
Lesnocker's Avatar
If it were me. I'd remove the fuel rail and do all 6. When they do come out bet ya money on them cracking an busting the tips off. Doing 1 or two also means expanding your vocabulary. Tried before and well there is a 3/8 gap between the hard-line and injector almost impossible to remove. My suggestion is just to take it all in one shot. New injectors fuel line and filter. Drain the tank by removing bottom hose on filter key to on position and pump into a bucket.
Lesnocker is offline
Old 10-30-2015, 02:14 AM
Lesnocker's Avatar
Also drain and change coolent. change hoses cap and thermostat. Barn finds are found in the barn for a reason. Rust, clutch or head gasket. Once running tripple check she's running cool. Once ya over heat your not going to like it. Lol every one of mine popped a head gasket. Once by a stuck 8.00 thermostat.
Old 03-31-2016, 09:41 AM
SaskS130's Avatar
Hey. Cool, I just got 2 1982 280zx at a barn too. Idk how long they have been sitting for. I am trying to start them in a couple days.
SaskS130 is offline
BUFF 90 Z32
05-20-2013 08:41 AM
vale2489
04-01-2013 10:07 AM
3ryce
02-03-2013 02:44 PM
Vintage240
08-31-2010 06:14 AM
280zdude
03-18-2009 08:46 AM
Quick Reply: New owner of a 280ZX
