ZX is dumping power steering fluid
Old Oct 8, 2013 | 09:31 PM
MrStiggy's Avatar
So, my car is dumping all the fluid out of the rack, It looks like it is coming from somewhere around the boot of the power steering thing that moves the wheel, I can't think of what it is called. Anyway I have sprung a leak, it hasn't happened before but now it just dumps fluid. Any help?
Old Oct 8, 2013 | 09:34 PM
Rack seals are toast. Fairly common problem.
Old Oct 9, 2013 | 08:03 PM
Bruce_Aldridge's Avatar
Lucas power steering stop leak. Two bottles per year
Old Oct 9, 2013 | 08:39 PM
evandubya's Avatar
Primer Grey FTW!
Or you could fix the problem, like Nismo suggested.
Old Jan 13, 2014 | 06:59 PM
davidcs130's Avatar
I have the same issue!
the fluid loss on the leak (coming from inside the boot on the drivers side) is enough to empty the reservoir leaving it overnight, other than that it works just fine. about how much is it to have it fixed? or can i just add some leak sealant to fix or reduce the leak while i get the money to get it fixed? would that make it worse when rebuilding it?
Old Jan 13, 2014 | 08:30 PM
The cost of the parts if you do it yourself (~$100). Probably $300-$500 if you have a shop do it. You could also source a rack from a junk yard / parts car.
Old Feb 17, 2014 | 04:11 PM
A few years ago, I bought a new rack from an import shop. I believe it was $165 or so. I bought it back in '07 when I first got my '82 slicktop. Also remember to use Dextron III transmission fluid in the power steering system. I thought I had leaks until I realized regular power steering fluid was causing the problem. I haven't had any more leaks since I changed to the correct fluid. It is in your FSM, and repair manual.
jslew
Dec 31, 2014 09:47 AM
duowing
May 31, 2008 09:05 AM
thxone
Nov 19, 2006 09:33 AM
y2daniel1981
Oct 16, 2006 01:46 PM
graverhead
Dec 14, 2005 12:39 AM
