ZDriver.com
-   -   Whats the Best ECU for the job? / long time no read (https://www.zdriver.com/forums/280zx-performance-technical-79/whats-best-ecu-job-long-time-no-read-28324/)
thetremendousti Apr 13, 2009 05:19 PM
Hey ya'll
long time since i've posted but I'm back on track now that its summer and i've spent the last 9 months away from my car (for the most part) and i have a question. After researching my memory I have come upon the conclusion that instead of buy new l28et injectors I already have 5 mustang SVO injectors. I figured I would buy one more, but the flow rate is much larger, heres the information I have but I figured i'd ask the pros :023: what ECU would work best with these injectors?
Merkur XR4TI / Ford SVOCan be found in Merkur, Cougar, Thunderbird, Mustang SVO 1985-88 turbo models. Can attach a hose with clamp for stock fuel rail.
Year/Model/CC/ Impedence/Part#/Color
2.3L Turbo / 370 / Low / E5ZE-9F593-AB / Brown (Stay away from green they are 315cc)
http://members.cox.net/linec/comparison.jpg
let me know what you think so i can buy one off ebay. I do have the stock '83 ecu and wiring already fitted so hopefully I will just be able to swap the ECU out *gulp*
":075:" or ":038:"?
NismoPick Apr 13, 2009 06:13 PM
The question is... How much do you want to spend?
As for your statement:
Only the 280zxt and Z31 / Z31T ecu's work with the stock 280zxt ecu wiring. Anything else gets a new efi harness.
Also, there are other (lower than 370cc) injectors that will work with your stock 280zxt ecu...
snwbrderphat540 Apr 13, 2009 06:59 PM
does your turbo 260 2+2 even freaking work yet?
thetremendousti Apr 13, 2009 09:21 PM
it WILL work once i get home!! i went home for break and long story short didn't get alot of time into it!! plus i've been stuck in the terrible state of illionis for school for the past eternity...
snwbrderphat540 Apr 13, 2009 11:09 PM
shut your mouth, this state is amazing! it just needs lower taxes in the city and nicer weather. you just need to be around for more of the summer time than winter to appreciate it. the inbetween seasons (spring and fall) are just drawn out way to long. thats the only reason i consider leaving this state and going south. when you done with school anywho? im out in tree weeks
