what do i need for turbo setup?
i am buying a rebuilt turbo motor and swapping it with my na motor.
what all do i need to do the swap. thanks for any info luke |
Turbo ECU, Wiring harness and Turbo Air Flow Meter at least.
That is of course only if you're not using an aftermarket engine management system with MAF or MAP sensor. |
put a turbo cooler on it, and a turbo oil filter as well to keep everything at smallest risk as posible.
Bigger turbo 25psi, that would be fun. How bout' water injection.
Ideally, you would have a big efficient intercooler. Complete stand alone sequential FMS 3" Mandrel bent exhaust system all the way back Custom turbo exhaust manifold w/ T4 mount Custom intake manifold with large heat shield Big Efficient blow-off valve Large precise external waste gate with no boost creep Forged pistons, crank and rods 550cc Injectors 60 - 80mm Throttle Body T4 Turbo w/ 30psi With proper tuning and adequate fuel delivery, it should make close to 600hp! The key here is that none of this is 'necessary' for your swap. What you have and what I mentioned earlier will get you down the road. If you want to upgrade in the process, it's a good opportunity, but can become very expensive VERY quickly. Speed costs money... How fast do you want to spend? :) |
Just bolt the turbo manifold and turbocharger onto your NA engine and go! :rolleyes: :D
I will be doing the same upgrade. Purchased a 82 ZXT Turbo motor, ECU, and wiring harness to drop into my 78 280Z.
Please comment on need for ZXT fuel pump and relays. Are they really needed or can I use my 280Z relays and a MSD or Walbro 255 fuel pump. Thanks Wayne |
