What is causing it to flood out???
Old Jul 3, 2003 | 11:25 AM
Do you think that there is a possibility that it is running a bit rich all the time? It might be another sensor or the fuel pressure regulator holding too high of fuel pressure. then, under most driving the throttle position switch tells the computer to run a certiain amount of fuel. At WOT, that percentage jumps up at 20%. Patricla throttle might still run good, just rich, but maybe the WOT command from that switch is causing just too much fuel. I had a simular problem, and it was the fuel pressure regulator. Once that was replaced, everything ran much more lean and I had better power and better gas milage.
If that's not it then maybe the Air Flow Meter is improperly adjusted. Its probably not the throttle position switch itself.
Lesnocker
Apr 17, 2013 10:49 PM
corbith
Oct 4, 2012 06:29 AM
irishdrunk
Jun 17, 2011 10:42 PM
domsgarage
16
Apr 5, 2004 06:37 PM
Carwood
Mar 6, 2002 01:40 PM
