Volvo Turbos
Old Dec 12, 2004 | 03:26 PM
applemansapple's Avatar
Volvo Turbos
ok well i made a post about turbos and i heard i could use a volvo turbo. im not looking on buying a expensive turbo cause im kinda poor and all so that sucks. well anyways are there any cheap but effiecent turbos i can get and apply to my 280 non turbo.
Old Dec 12, 2004 | 03:58 PM
and how would go about finding one of these if i were 2 purchase one
Old Dec 12, 2004 | 07:37 PM
Dorifto's Avatar
Junkyard turbos are your best bet - If you're bent on a Volvo turbo (it should work), you can find one at a european-only junkyard or parts place, but expect a pretty penny for one. If it were me, I'd find a wrecked DSM (Eclipse/Talon/Laser) and pull the turbo off it, or find a Mustang SVO or TurboCoupe Thunderbird and use that turbo. The DSMs have T28s, internal wastegate; and the SVO cars run T3s, not sure about the gate. You could also use small diesel turbos as well, although they are tuned more for high pressures than spool-up (larger turbine trim and housing). Great for flow, not so much performance though.
Or just find a turbo Z engine and drop that in ...
Hope this helps,
Dave
Old Dec 12, 2004 | 09:25 PM
Las VegaZ's Avatar
Figure out the manifold first. If you are using a stock one, figure out what turbo's will bolt to it. If you are having a custom one made, then figure out where the turbo will sit, and if you have room for a wastegate, or will it have to be internal. That will tell you what turbo you can use.
Old Dec 13, 2004 | 04:02 PM
Well the z im getting is a 80 non turbo and stock on that part 2. well like i prob am gonna get a turbo from a junkyard and all cause its the cheap speed boost for me that im looking for.
Old Dec 14, 2004 | 08:14 AM
Well, have fun!
Oh, have you done a search in the 280zx section and read up on the old posts about turboing a non-turbo engine?
Old Dec 14, 2004 | 08:14 PM
assimilated420's Avatar
yeah, you really cant just stick a turbo on it and expect it all to be fine....better read the posts before doing major work
Old Dec 17, 2004 | 10:15 PM
Las VegaZ's Avatar
Well, when you go to the junk yard bring the manifold with you and see what will or will not work, and check to see if it is oil or water cooled. That is also a big deal. And after you get that sorted out then figure out engine management. Then figure out your plumbing, intercooler and exhaust. Then take the car and find a really good tuner and have it tuned to run on the safe side, low boost, then after that you can slowly turn the boost up, having it re-tuned everytime you up the boost. Oh and get ready to pull the motor.
93twinturboZ32
Feb 17, 2011 04:13 PM
Mrmoose
Feb 1, 2011 12:37 PM
skittle
May 14, 2007 10:34 AM
nis88300zx
25
Nov 2, 2005 07:53 PM
tt300z
19
Feb 2, 2005 05:49 PM
