Turbo Vac lines
Old May 28, 2009 | 04:17 PM
User395's Avatar
Turbo Vac lines
When I bought the car most of the turbo was taken a part so, I don't know where I need to connect these vac lines. I looked at the FSM and it is kinda hard to tell.
Can someone tell me which vac lines need to go where? These two, I think one goes the the wastegate actuator and the other is for the boost gauge???
I don't know which is which.
Thanks for the help!!
Old May 28, 2009 | 07:55 PM
straight hate's Avatar
Stock; Intake side and Exhaust side both run into a T fitting and then to the wastegate actuator.
To hook up a boost controller, you can block off the exhaust nipple, run the hose from the intake side of the turbo to your controller then back out to the wastegate.
Hope this helped some.
Old May 28, 2009 | 08:43 PM
Sweets's Avatar
Usedta be Justin260z
^Edzachary.
Anyone know why they use two vac lines to supply the wastegate? More accurate possibly? Faster engagement of wg? Are there any drawbacks to capping off that top nipple?
Old May 28, 2009 | 10:19 PM
Connect to wastegate or boost controller...
Old May 29, 2009 | 06:01 PM
ooooooohhhhh thats a clean turbo, wished mine looked like that.
Old Jun 1, 2009 | 06:20 PM
User395's Avatar
Let me know if i hooked these up right.
Where does this heat shield go?
Does this ground line go underneath or on top of the J pipe bracket seen here or does it really matter?
Hate to bother you guys but since I didn't take it off . . . . kinda don't know where is needs to go.
Old Jun 2, 2009 | 07:17 AM
Yep, that's how the hose should be connected. And the stock location for that ground wire is that 10mm bolt just to the left of the j-pipe bracket, where the other ground is.
Old Jun 2, 2009 | 08:11 AM
duowing's Avatar
NisTuner
that heathsield goes on the manifold. It goes on the front, but more towards the back. It's just for the wiring to the O2 sensor.
Old Jun 3, 2009 | 05:46 AM
User395's Avatar
Would it be okay to have two grounds there?
Old Jun 3, 2009 | 10:57 AM
Yep. There's 3 10mm bolts in a row right there, you can use any of them for grounds. Just make sure there is a clean connection.
86_VG30ET_Z31
Oct 25, 2011 09:39 AM
omniserv
May 19, 2011 06:26 PM
nis88300zx
Jan 21, 2006 03:09 AM
twister
Mar 14, 2002 04:17 PM
