Turbo Factory Vs Turbo Aftermarket
I found a datsun 280ZX purported to be a factory Turbo model in Brisbane in a card yard.
I suspect it is not factory turbo but I may be wrong. I suspect the car is not factory original. What do you think? I didnt think they brought turbos to Australia and none before 1981 at least? Details below. Engine Number is L28-487576 Model designation is 280Z T bar roof. 5 speed manual. Tappet cover does not have a embossed Turbo on it. Turbo Pipe has embossed " HKS Turbo" The vehicle is plated 5/80 and is showing 145,000 Klms on the odometer (can't guarantee that is original,). VIN Number is HGS130 165902. Apparently Turbo was fitted by a Nissan dealer. Are there any/many differences between Factory and after market turbos? Any traps for young players? the car is reduced to $3000 it is a Mark 1. |
If you suspect that your country did not get the factory turbo Z, then you may be right. 5/80 is a little too early for the 1981 280ZX turbo. In fact, I think they were produced part way through 1981, probably mostly preorders.
Some other distinctions are the distributor; the Nissan turbo Z has a much larger diameter distributor cap and a larger diameter Air Flow Meter. You can compare these to your own cars as I see you already have some 280zx's. HKS is aftermarket. I think the brand of turbo Nissan used is Garrett(?) ...or is that the style of turbo. I haven't owned a turbo Z yet. |
I always thought the first turbo was considered a "1981-1/2" model.
I think it is an aftermarket bolt on, the stock on is like Bleach said a Garrett turbo. If you look at my cardomain page on page 7, you'll see the stock turbo. Another thing to add is that the turbo models of the 280ZX had a different front grill from the naturally aspirated models.
http://www.cardomain.com/id/lifegrddude John 82ZXT |
Factory Turbo?
Hi, SteveGee
Zcar garage has info on L28ET engines all the dates and numbers on the blocks and heads. http://www.geocities.com/zgarage.2001/engine.html Although Australia did not get the L28ET 280 ZX for sale there are imports around. Patrol had an L28ET and I am told some Skyline have them. Hope it helps mate! sounds like a good price If it was in Adelaide I'd be interested. |
