turbo ECU
Old Oct 11, 2005 | 03:55 PM
efrain's Avatar
turbo ECU
Will I get bennefits from changing the stock ECU of my 81 N/A, to the ECU of a turbo 280zx? If yes, will it be a plug on, or will I have to modify something?
Old Oct 11, 2005 | 05:27 PM
lww's Avatar
lww
Head Muckraker
You will get no advantage. You will loose gas mileage because your car will run very rich at high rpm's.
These computers are very simplistic (ie. 1975 technology) and are not flexible. You do something to the motor that the ECU doesn't understand and it will ignore whatever you've done and keep treating it like you didn't do anything making the car run like crapola. (<Technical term from the '80s)
Old Oct 11, 2005 | 06:47 PM
Not to mention that fact that the ECU plugs are completely different... You'd have to swap the entire wiring harness, and w/ out all the turbo sensors hooked up right, won't work right anyway.
Nice try tho!
Melspace02
FS: 300ZX (84-89)
Sep 5, 2012 06:28 PM
Spyder Z 15
Aug 20, 2008 12:28 PM
johnsonsz31tt
May 7, 2008 07:27 PM
thunderz
Feb 12, 2006 06:46 PM
teamadidas
Jun 2, 2005 04:41 PM
