tranny swap
I know there is alot of info on the board about swapping the auto to manual but there is no part list. Could someone please give me a parts list so I don't forget anything. My car is daily driven and can't be down because I forgot a part or got wrong part. Thanks in advance
I'm not sure about anyone else but this is what mine was:
1.Manual transmission(assuming its a complete transmission) 2.flywheel 3.bolts(flywheel to crank are longer on m/t than a/t) 4.cover plate (goes behind flywheel against block,matches m/t bellhousing,a/t has a 2 piece version) 5.Clutch Master cylinder & lines(& reservoir) 6.clutch slave cylinder & lines 7.clutch disc 8.pressure plate(& bolts) 9.throwout bearing 10.shifter 11.shift boot & cover plate 12.shifter dust cover 13.clutch pedal assembly(with bolts) 14.m/t crossmember 15.m/t driveshaft 16.brake pedal assembly(from a m/t car or cut the sides of your a/t off to match) 17.shift knob 18.bolts(transmission to block) 19. 10,12,13,14,15,17mm sockets, 20.ratchet 21.breaker bar 22.2 rolling jacks 23.a pair of jackstands 24.a drill and bit for drilling the holes for the m/t pedal 25.sawzall if you decide to trim the a/t brake pedal 26.rtv grey sealant 27.4 quarts of gearlube 28.And a little elbow grease. :D |
Buy a whole parts car that way if you wind up needing some minute piece then you can always go to the parts car. I speak from experience
Hey, thanks for the list. I allready have all that stuff, but it is good to know that I did not forget anything. Now, I am glad that I got the flywheel bolts as I did not know there was a difference in length.
The flywheel bolts are only around a 1/4'' longer but you surprisingly need that extra bit a lot more than what I realized before the flywheel sheered off and cut a gape in the bellhousing of my B13.(First tranny conversion,3 years ago)
Trust me ,you don't want to have to dig the remnants of those bolts out of the crank,it sucks. |
