tranny fluid?
Old Aug 19, 2006 | 09:31 PM
skittle's Avatar
Taste My Rainbow
tranny fluid?
is there a trick to getting the bolt out of the tranny to fill it with fluid? I hate square bolt heads!!!! I got my car running finally but it makes noise when I drive cause I need fluid in there!!! i'll quit driving it untill i can get some fluid in it though.
Old Aug 19, 2006 | 09:49 PM
turbobluestreak's Avatar
ok if you can't get it out then stop! One of my trannys was locktighted in. Take out the revers light and fill it though that. I think you'll be a little extra full but better then working on a fill plug that might not come out or worse you strip the treads trying to get it out.
tbs
Old Aug 19, 2006 | 10:40 PM
thxone's Avatar
Have you tried useing the square head on a ratchet yet? My question is if the fill hole is up high how do you get the old fluid out...not that you need to if you are just filling with more fluid.
Old Aug 19, 2006 | 10:50 PM
skittle's Avatar
Taste My Rainbow
THERE IS A DRAIN HOLE ON THE BOTTOM OF THE TRANNY. AND ON THE RIGHT SIDE LOOKING TWARDS THE FRONT OF THE CAR IS A SQUARE 17MM BOLT THATS A BITCH TO UNDO.
WHAT DO YOU MENA BY THE REVERSE LIGHT?? DOES THAT HAVE A PLACE TO ADD FLUID?? i THOUGHT IT WAS JUST SOME ELECTICAL CONNECTORS.
Old Aug 20, 2006 | 08:45 AM
skittle's Avatar
Taste My Rainbow
Does Any One Have Pics Of Where The Backup Lights Coneection Is So I Can Add Fluid To My Tranny??
Old Aug 20, 2006 | 12:21 PM
jfairladyz's Avatar
he means remove the reverse light switch on the tranny. Just look for the wiring going to the switch.
With the actual fill plug: have you tried using heat and a hammer?
Old Aug 20, 2006 | 05:34 PM
dont touch that 17mm bolt, it holds the tranny internals in place, you do that, you may be in for it. just use a impact gun and the plug will come out, or a tub on a breaker bar. just make sure its in there solid
Old Aug 20, 2006 | 05:47 PM
nismo619's Avatar
1/2 inch breaker bar worked for me ! make sure to use some teflon tape when yourputting back in the screw.. i found out the hard way....
Evan Faris
Jul 25, 2013 01:03 PM
tonsoffun300zx
Apr 15, 2008 05:52 PM
2.8.0.Z.X
Mar 26, 2008 09:18 AM
KasbeKZ
Jan 27, 2008 06:45 PM
waterdogzx
Apr 4, 2005 11:40 PM
