tmcharper 1983 280zx non-turbo
Old Aug 9, 2008 | 02:41 PM
tmcharper's Avatar
just replaced (1) injector now the car starts and ideal's ruff, if I try to put any throttle it dies!
Any help would be aperciated
Old Aug 9, 2008 | 04:56 PM
n e e d m o r e i n f o . . .
Did the car run fine before you changed the injector?
Did you disconnect any sensors (AFM, CHTS, TPS)?
Does it have proper fuel pressure?
Did you do anything else to the engine bay while replacing the injector?
Old Aug 9, 2008 | 07:21 PM
did you mess with the timing, either way, we need more info just like nismo said!!
Old Aug 10, 2008 | 12:42 AM
lww's Avatar
lww
Head Muckraker
Check the connector on the AFM and run through the AFM voltage test in the factory service manual.
Need much more detail to have any chance of helping you out here...
Old Aug 25, 2008 | 07:03 PM
tmcharper's Avatar
fuel injector issue!
not sure what happened, may be just needed to be primed? anyway started and going strong.
thanks for the tip's
Frenchie
Jan 11, 2015 10:42 AM
280zx2by2
Jul 3, 2008 07:36 AM
chrischicoine18
Jan 31, 2007 12:02 PM
NismoZigma
28
Aug 11, 2006 12:57 PM
