Timing advance spec? 83 ZX NA
Old Apr 9, 2020 | 06:06 PM
aestey's Avatar
FSM says 8.5 deg at 1400 rpm, and up to 15 deg Vac advance depending on amount of vacuum.
I checked my 83 NA ZX:
10 Deg at idle with no advance (both electronic and vac advances disconnected)
12 Deg at idle with everything hooked up
30 Deg at 2000 rpm
40 Deg at 2500 rpm (the marker ends at 30 Deg advance, 40 is just a guess, but the mark advances so far down the flywheel you can barely see it)
Do these seem correct? An advance to 40 at 2500 rpm seems awfully high
FubarI33t
May 1, 2010 05:56 PM
audiofreak97
Mar 13, 2010 08:30 AM
zcarron
Dec 27, 2007 07:04 PM
domsgarage
Oct 31, 2006 06:04 PM
91zxtt
15
Jan 10, 2004 07:08 PM
