Throttle body cleaning in 280ZX
Hi,
Has anyone cleaned their Throttle body cleaning in 280ZX NA? I was going to do that this past weekend but couldn't figure out how to remove the hose just ahead of thottle body with all the connections. Thanks in advance.. SurgeNJ |
Yeah I had to once, when it got gummed up with antifreeze. I unhooked the main big line going into it. And sprayed carb cleaner, and it smoked and cleared right up. Because I couldn't go past 2000rpms. A hose burst, and sucked antifreeze into my air system. I took it all apart. And cleaned it up. Hope this helps. But I would suggest fuel injector spray if available. The carb cleaner is not good for your catalytic convertor. I don't want you to damage your convertor, because of my account. Later
I tried removing it but it feels like it will break if I try to remove it... Can I remove the air flow meter first & then remove that hose?
Its a lot easier if you pull out the AFM first.
Yeah drew is right. It is easier to remove the air flow meter. Mailnly screws on the hoses, and a couple bolts on the bottom. Hope this helps you out. Get back if it doesn't, and I will try to explain how to do it step by step.
actually i was thinking of doing this same thing over the weekend, even if im not really having any problems with air flow you think it'll still make a noticable difference?
