ZDriver.com
-   -   Temp gauge suddenly not working (https://www.zdriver.com/forums/280zx-performance-technical-79/temp-gauge-suddenly-not-working-13645/)
davidjoe007 Jun 27, 2005 12:49 PM
Hi Everyone,
I was working in the motor compartment changing some old fuel lines and then adjusting the timing...everything going smooth... The car is warm by now... I took a look at the gauges and the temperature gauge had no reading. I think a loose wire in the motor compartment but couldn't find any loose wires. Any suggestions. :confused:
WildmaN Jun 27, 2005 02:26 PM
Check your fuses, if that is good, check your temp sensor, and also the plug that goes into the front of the engine. I found out before when I was running my Z, and the temp was not working. I looked under the hood, and found a loose plug in front of the engine. Jiggled it around a bit, and the temp gauge worked again. Just had to secure it with another clip that goes around the plug itself. Hope this helps you out! And again glad to hear you got another Z, good luck to you! :D
davidjoe007 Jun 28, 2005 11:17 AM
thanks
Thanks... the coolant temperature sensor right above the thermostate housing was loose.
Thanks again... it great to be driving a Z again. 83 t-tops baby. :cool:
WildmaN Jun 28, 2005 01:43 PM
Right on man glad I could help you out. Anyway that is a sweet Z bro'! Take care of it, and get a good decent alarm on it. :D
Z you later Mar 7, 2023 09:28 AM
Dave,
Where in the Bay do you live?
I'm in San Mateo.
280Zx Turbo 5 speed.....appreciate my Z and others.
