stroker crank?
Old Mar 17, 2005 | 10:48 PM
mattduskater's Avatar
stroker crank?
ok I found this on ebay auction
what I want to know is, is this a crank from another car that can be used to stroke a z? It says it has never been in a z but came out of a disel engine .
Old Mar 17, 2005 | 11:01 PM
dr. buddha's Avatar
Z Extreme Guy
yes its the one you want to strok your z
Old Mar 18, 2005 | 07:20 AM
DoTheDrew888's Avatar
The crank was pulled from LD28 engine. It is a 2.8L diesel engine in early '80s Maximas. Be carful if you are considering doing this project, it is a lot more in depth than just throwing a new crank in. Check out the Nissan L6 forum on hybridz.org to learn EVERYTHING about the 3.1 stroker.
Old Mar 18, 2005 | 10:49 AM
Yes, it is a lot of work. You have to get new pistons, connecting rods, grind away metal inside the block... not a fun job. Not worth it either unless you build up the rest of the engine. Spend $6,000 on the whole engine, or don't do it at all. Just the bottom end will cost you $3000 to stroke and rebuild it properly.
Old Mar 19, 2005 | 11:56 AM
fairladyVT's Avatar
I heard those are near impossible to get balanced. They shake the crap out of your car and never feel smooth.
Sm1nts2escape
Jun 25, 2013 01:21 PM
jdunbar
Sep 5, 2012 07:10 PM
byrneZ
16
Jan 28, 2008 02:04 PM
ericshere03
Jan 22, 2008 09:23 PM
motoist
Apr 11, 2002 09:33 PM
