Starts at high idle
Old Aug 24, 2007 | 09:04 AM
CraigS's Avatar
Starts at high idle
Hey, I'm getting so sick of my car so please help out if you can.
The car in a cold start, starts really rough and then idles at 1500 untill it slowly warms up and idles down. Right after start up, if you press on the peddle it will bog down then rev up. What could cause this? I'm so sick of my car running like ****.
Old Aug 24, 2007 | 09:06 AM
checked your temp senders?
Old Aug 24, 2007 | 09:07 AM
CraigS's Avatar
Its a 79 so i dont think it has the CHTS.
Old Aug 24, 2007 | 11:57 AM
Air regulator, timing, mis-adjusted idle screw, vacuum leak on the intake manifold or major vac lines, AFM....
Old Aug 24, 2007 | 08:26 PM
that sounds like almost perfect z cold start to me, if only mine would be that smooth. maybe cause a took out all my cold start stuff.
Old Aug 25, 2007 | 12:33 AM
Heat Rave R's Avatar
Hm, that sounds almost exactly what's going on with mine ever since I did the Z31T ECU/MAF conversion. Doesn't happen all the time to me though, but mainly when it's a cold start.
In my case, if it is a vacuum leak, I haven't seen anything out of place.
Old Aug 25, 2007 | 02:57 PM
z-hag's Avatar
Queen of Yachts
i have found my z31 turbos liked to warm up for a few minutes before takeoff---the NA only wanted her oil prwessure to come up before going anywhere....
madkiwi
Jun 6, 2015 07:40 AM
spaceviolence
Apr 8, 2014 04:23 PM
renny
Sep 16, 2010 08:36 AM
Lanoi
Apr 9, 2010 10:53 AM
Petezcar
Jan 21, 2002 02:40 PM
