Stalls after about 3-4 minutes of running
Like the title says, after about 4 minutes, (Mind you, I can drive and do everything normally here) the car up and stalls. The tach drops to zero and that's all she wrote. If I try to start it immediately, it wont start. Give it about 5 mins and it starts right up again. Fuel pump sounds fine, no fuel leaks anywhere.
What else can I check?:115: |
Welcome to ZDriver!
An engine needs 3 things to start: -Proper fuel delivery -Proper spark delivery -Proper compression So when it won't start: Are all6 spark plugs sparking? Injectors spraying fuel? (you can pull a spark plug to see if it's wet or dry) The usual culprits are: CHTS, AFM, fuel pressure, and/or ignitor. Make sure you download the FSM as it has diagnostic steps for all this. :) |
my Zx
Hey Redhare my Datsun is having the same problem please let me know what you did to fix it :D :D
