Spark plug cross-reference...
Old Jun 21, 2006 | 03:00 AM
rxKaffee's Avatar
I was wanting to get some good high quality sparkplugs for my car, but I am going to be replacing my L28 with an RB20 soon. I discovered that there is very little difference in the sparkplug for the two. The L28 calls for a BPR6EIX-11, and the RB20 wants a BCPR6EIX-11. As per the chart here the only difference in these two plugs is 'Hex size 5/8"'. I haven't measured our spark plugs, but I've been told that the head on them is 5/8" as well.
Are these identical spark plugs with different numbers? Could I use the BCPR6EIX-11 in my L28?
Thanks, rxKaffee
Old Jun 21, 2006 | 05:20 AM
PooFlinginMonke's Avatar
Not sure about the IX but I did find the slightly split electrode spark plug that many auto parts stores now claim is the supercession to the bpr6es11 was far less resistant to melting off the tip upon extreme usage.
Either way, I am still a huge fan of the "EV" series of ngk plugs which are near impossible to find now.......at least they were where I looked.
Old Jun 21, 2006 | 03:49 PM
rxKaffee's Avatar
Do you have the part number for this plug? Maby its the BCPR6... ?
Old Jun 22, 2006 | 05:10 AM
The letter C just stands for the smaller hex size though the plug is otherwise identical.
Old Jun 22, 2006 | 02:31 PM
rxKaffee's Avatar
Excelent, so the BCPR's should work just fine where BPR is called for.
Do you know the "normal" hex head size for the BPR?
Old Jun 22, 2006 | 03:36 PM
RodMoyes's Avatar
Doesn't post much...
Yes, they are exactly the same plug with the exception of the hex size. I have used both. At one point, I wound up with 5 and 1 somehow and there was no issue.
Rod.
G30
Oct 14, 2014 03:54 PM
Fairladyz1990AF
Apr 24, 2014 04:15 PM
sidneyam
Mar 11, 2011 07:24 PM
3XAZOWNER
Dec 29, 2008 08:39 PM
mnelsonz
Sep 26, 2002 10:45 AM
