some problems
Old May 5, 2005 | 11:15 AM
Captain caveman's Avatar
some problems
I'm having some problems with my car. I'm not quite sure what is. When I run the car. If I give the vehicle gas when it is in neutral it responds and the rpms will go up, but once I let my foot off the gas the engine will eventualy stall. It only happens when I give it gas. If I start the car the engine will idle normaly but once I give it gas that and then let it go that changes
Old May 5, 2005 | 12:29 PM
Does it do this only when the engine is cold or both cold and when fully warmed up?
Old May 5, 2005 | 03:18 PM
hmmm, I don't know. Maybe my car just needs some tuning up. new fuel filter, oil change, changing other fluids and etc. I also have another problem. It's related to my electrical. Sometimes my car wont start. I'm thinking it maybe a bad fuse or my ignition switch. I know I'm going to eventual need to replace ignition switch because I can currently stick anything in it to start it up
Old May 5, 2005 | 03:37 PM
Fast240Z's Avatar
lol, that's a common problem with most Z's, almost any kind of flat key can open/start them.
Old May 5, 2005 | 04:47 PM
jfairladyz's Avatar
Hey check you're ignition module on your intermittent starting problem.
Find out if your cars only stalling when it's cold or warmed up or both. Can narrow it from there.
Tune up couldnt hurt though.
Old May 5, 2005 | 07:00 PM
felix69's Avatar
a bad problem, lol i pull the keys to lock her when i go in the store for a second to keep the ac going lol.
Old May 5, 2005 | 07:04 PM
Fast240Z's Avatar
lol, I've mystified people with that. It's somewhat of a nice feature when you lock your keys in the car, any key will open it.
Old May 5, 2005 | 08:28 PM
juggalo280ZX's Avatar
My dads jeep wrangler key works in my passenger door but nowhere else! fudder mucker keeps stealin my cigarettes!
...Wait a minute... my actual car key doesn't work in that door but everywhere else it does. I need to investigate this!
Old May 5, 2005 | 09:21 PM
DynamicJ's Avatar
Z8 driver
maybe old dad's playing a trick on ya
Old May 5, 2005 | 09:36 PM
Time to HIDE your cigs I guess.. or stop smoking.
Old May 5, 2005 | 10:39 PM
There are three things in life that I would not be able to stop doing:
1. wreckless driving (it's only illegal if you get caught. krispy kremes in the rear storage bin helps.)
2. smoking (it's only illegal if more than the pack and letters are green.)
3. my girlfriend (it's only illegal if she looks, acts, and sounds 15, claims to be 19, and you get caught.)
I follow all related laws except for #1, but no one can prove that.
Old May 6, 2005 | 06:27 AM
DoTheDrew888's Avatar
There is a vacuum line that runs from the charcol box to the bottom of the throttle body. If that is disconnected or cracked it will cause the problem you just described. I had the same problem.
Old May 8, 2005 | 01:57 AM
hmmm. I do have a vacum hose that isn't even attached to anything and my car does sounds like it has a few vacum leaks too. I bet if I replace my vacum hoses my car will run better.
ZBspires
Aug 30, 2013 07:33 AM
86z31
Aug 16, 2010 06:14 PM
turbo84z
Jan 21, 2008 02:26 PM
duowing
Sep 30, 2006 08:26 AM
hondahunter
Mar 18, 2003 02:45 AM
