Short?
Short?
1981 ZX Turbo engine and accessories keep running when key is in off position have already installed new ignition switch and ignition relay. Funny thing is that it runs perfectly when I remove the ignition relay..
It started before I installed the ignition switch. A new twist. I found that if I pull the fuse that controls the cruise control, the back up lights, turn signal ,and seat belt alarm, everything works as it should.
