Short?
Old Jun 29, 2024 | 09:50 AM
ruppert23's Avatar
Short?
1981 ZX Turbo engine and accessories keep running when key is in off position have already installed new ignition switch and ignition relay. Funny thing is that it runs perfectly when I remove the ignition relay..
Old Jun 30, 2024 | 04:42 AM
Kickstand80's Avatar
Did this issue start before or after you replaced the ignition switch and ignition relay? Why did you replace them in the first place?
Old Jul 1, 2024 | 12:20 PM
ruppert23's Avatar
It started before I installed the ignition switch. A new twist. I found that if I pull the fuse that controls the cruise control, the back up lights, turn signal ,and seat belt alarm, everything works as it should.
Old Jul 1, 2024 | 02:53 PM
WTF..........you have a very interesting problem. I have no idea what it could be. Somehow you have to be powering the ECU, injectors, distributor, EFI relay ect.
Did you smell anything getting hot?
kamalnasser2222
Sep 8, 2021 10:40 AM
Tyler_81_280zx
Jul 19, 2021 06:43 PM
TBK1
Nov 5, 2008 06:55 AM
Creator
May 31, 2004 12:59 PM
Zwolftech
Apr 5, 2002 03:09 PM
