short?
Old May 15, 2005 | 09:08 PM
apollo's Avatar
Pro Pumpkin Carver
short?
So here is the deal . . .
The car ran and started fine. Went to gas up, turned her off, went to start her up and then nothing. No click, no struggle to start. Nothing. Pop started her to get out of there and today all I got is that the starter is good, battery is good, cant jump start the starter even by bridging the gap between the solenoid and ignition switch, the lights dim only after I try and start if the 1st time after having reconnected the battery. Once I do this they stay dim and the fuel pump doesn't come on and power is minimal. the car runs if pop started but I cant turn it over. All electrical current is cool, checked with a multimeter. Electrical signs are fine until I try and turn it over. then they go dim and stay di until I disconnect the positive wire and reconnect it resetting something. lww checked it out and couldn't seem to find anything either. Any suggestions?
Old May 15, 2005 | 09:28 PM
Dorifto's Avatar
Mine does this as well sometimes. It's always been a bad connection on my ground, possibly messing something up with the voltage regulator? I'm not sure on that though. All I can say is my Zed likes to blow up old batteries, or batts with under 10 volts in them.
Old May 15, 2005 | 10:21 PM
antisub's Avatar
If you've got an extra battery laying around, try swapping it out. Sometimes a cell in a battery will go bad, I've had that happen to me a couple of times.
Old May 15, 2005 | 11:39 PM
tekanitrus's Avatar
i had the same issue, even had the starter bench tested...
replaced the starter under my dad's advice (he's had a bunch of z's in his days)
even though it seemed good and the guys that tested it said i didn't have to.........
been a dream ever since
<shrugs>
Old May 16, 2005 | 12:08 PM
apollo's Avatar
Pro Pumpkin Carver
Well i just got home from work and im about to try again. Gunna check the ground and battery connections. Other than that i am stumped. where is ther voltage regulator on our Z's? my Z is an 82.
I had bought a starter yesterday and returned it becuase it didnt fix the problem. The thing to remeber was that i didnt mess with anything. the Z was driving and then wouldnt start, but ran if pop started
Old May 16, 2005 | 01:39 PM
Get all new battery cables! simular things happened to me and it ended up just being the stupid cables.
Voltage regulator is INSIDE the alternator. These cars run what is called an Internally Regulated Alternator.
I'm not sure how you checked that your battery is good. Take it out, charge it on a charger overnight. Put it back in with clean connections. Hotwire the starter solinoid like you described. If it won't start, then the battery is probably bad even if it reads 12v. Like was said above, also try a battery from someone else's car.
Old May 16, 2005 | 02:27 PM
assimilated420's Avatar
just make sure the battery puts out enough to start your car.. if you got a lower Cold Cranking Amp battery.. or a lower Warm Cranking Amp battery.. then you can hve problems like those described.. make sure your battery is rated for your starter
Old May 16, 2005 | 08:49 PM
lifegrddude's Avatar
Externally Wastegated
Could be a worn out ignition switch. I couldn't start my Z either and had to put a push button starter in for a while till I fixed it.
Old May 17, 2005 | 03:56 AM
Yeah I had that same kind of problem with my '81. I would sit there and go back and forth with the key. From on to start etc... Then I decided one day that maybe it was the ignition switch. And $10 later, it started every time, first time. Little by little in the 5 years I have owned a Z. I have learned more and more. Hope this helps!
Old May 17, 2005 | 01:54 PM
apollo's Avatar
Pro Pumpkin Carver
I just wanna say thanks to everyone. you guys are always a huge help.
As far as the Z goes . . . . .same old crap. its always is to be the simplest thing, and always gets over looked. i needed new battery cables . . .DUH jake!! they were all nasty and had corrosion all the way through. replaced them and she started right up.
Old May 17, 2005 | 02:21 PM
Glad we could all help you out. I have learned that it is the simple things that get overlooked!
Old May 17, 2005 | 08:55 PM
tekanitrus's Avatar
a wise man once said it's the little things that kill.
Old May 18, 2005 | 05:24 AM
You hit the nail on the head man! Well said bro!
Old May 21, 2005 | 08:13 PM
EatmyDust's Avatar
What about the balast resistor? could that have anything to do with it?
Gerbil
Feb 18, 2014 09:56 AM
hogboy36
24
Nov 4, 2005 08:04 AM
BlinginZ
Jun 30, 2005 10:43 PM
nka04a
Mar 15, 2005 07:02 AM
lilx240z
May 6, 2001 06:43 AM
