question..
Old Jul 16, 2005 | 03:05 PM
xsciuga's Avatar
question..
Ok so I just started diving into my rebuild project, and I start taking my baby apart...and it's the first l28 I've worked on, so, besides the bolts on the top of the intake manifold in sight, where are the other ones? It feels like it wants to come off, but I can't see any other fricken bolts holding it on, I'm assuming there are some under neath? someone help. Sorry for the iggnorance, but gotta learn.
Old Jul 16, 2005 | 03:09 PM
assimilated420's Avatar
underneathe it bolting both to the exhaust and intake.. they are between the plunems of the exhaust.. if you have a mirror you can prolly look under there to see
Old Jul 16, 2005 | 03:21 PM
xsciuga's Avatar
Thanks, I knew there was some bolts chillen underneath there, just popping my cherry with this thing.
Old Jul 16, 2005 | 09:21 PM
jfairladyz's Avatar
Remember to disconnect the EGR tube too or you could end up twisting it out of position, and then it's even harder to line the manifold back up when you put it on then it already is.
Those bolts can be a tough find the first time around. What I did was take a Sharpie and make a mark on the valve cover directly above where the bottom bolts are, that way when I go to put them back in, or next time I gotta take it off, I'll know exactly where to find them.
Old Jul 17, 2005 | 06:41 AM
xsciuga's Avatar
Ok, I took 2 bolts off..but I think Imight be screwed haha..I felt 2 screw things without heads..Either the bolts I need are broken off, or they are guides for the intake manifold, someone please tell me they are guides...
Old Jul 17, 2005 | 07:59 AM
apollo's Avatar
Pro Pumpkin Carver
Damn, looks like your in the same boat i was this past week. those are bolts and there should be 6, i believe, that the intake and exhuast manifold share. check it out . . .
Old Jul 17, 2005 | 08:26 AM
xsciuga's Avatar
God damnit. I think a tear just rolled down my cheek...Thanks alot for that picture, it helps ALOT.
Old Jul 17, 2005 | 09:34 AM
xsciuga's Avatar
Ok, thankfully, the bolts were NOT broken, had NO problems and it's all off now..Great feeling..And THANKS ALOT for the pic, it helped.
Niku-Sama
Other Cars
Jun 24, 2011 10:25 PM
domsgarage
Oct 11, 2010 07:44 PM
