Please somebody help me:
Old Mar 19, 2007 | 02:05 PM
14922zx's Avatar
Talking Please somebody help me:
i did a tune-up-- new wires,spark plugs,new rotor and cap,pvc valve,new fuel filter,new air filter,new ic unit,and it runs great at idle,but when i hit the gas it misses and farts and will not run very well at all,i adjusted the air and idle rpm,it was runing better before i tuned it up ,can i be helped please, 14922zx
Old Mar 19, 2007 | 02:15 PM
thxone's Avatar
Double check to make sure the cap is all the way seated and the snaps that hold it on are secure, check all the plug wires and make sure they are in correct order, did you wash the engine? Double check everything you touched and if need be put it back the way it was before the tune up one piece at a time till you find the problem.
did you check your timing?
Old Mar 19, 2007 | 02:31 PM
thxone's Avatar
Is it a Turbo? If so, and you put a new IC (Intercooler?) Did you make sure all the clamps are tight? Cause if not, as soon as it makes boost and pressurizes it's not going anywhere fast and sounds like crap.
Old Mar 19, 2007 | 02:34 PM
lww's Avatar
lww
Head Muckraker
IC = Ignition Control module. Black box on the side of the distributor.
Old Mar 19, 2007 | 03:07 PM
thxone's Avatar
DOH!!! I am such a noob
Old Mar 19, 2007 | 04:01 PM
lww's Avatar
lww
Head Muckraker
Nah, you just hang out in the HondaTech.com forums too much!
Old Mar 19, 2007 | 04:15 PM
14922zx's Avatar
Cool help
i checked it all at least 5 times,i did put a bottle of gumout in the tank with about 9-10 gal,that's about dubble the normal amount,i done the same thing with my 450sl mb about a mo.ago, it did about the same until it all was gone,this could be the same, what do you think?? 14922zx
Old Mar 19, 2007 | 05:14 PM
thxone's Avatar
Hmmm maybe, I know I have added stuff to my tanks in other cars before and they sucked to drive untill I either ran it out or topped off the tank.
Old Mar 19, 2007 | 06:34 PM
Ryan280's Avatar
First off is fire order ok? Sounds like it.
I did the tank additive too but without problems.
Old Mar 19, 2007 | 06:56 PM
14922zx's Avatar
Cool help
well tomarrow i will top off the tank and see what gives, my car is non - turbo and i did not fool with timing,sowe will see,Thanks guyes,14922zx
Old Mar 19, 2007 | 09:04 PM
duowing's Avatar
NisTuner
Also one thing you might want to look into. Try and find out if your TPS is adjusted properly. That made a big difference for me. Also did you put a new Ignition Coil in along with the new IC? Even if the timing is "correct" before the new IC, at least for me the timing had to be reset after hooking up the new IC. If you've upgraded every part of your ignition system save for your coil you might want to do that, just so you can be sure with everything there. Also check your plug wire order as was mentioned.
Old Mar 19, 2007 | 10:30 PM
RodMoyes's Avatar
Doesn't post much...
You probably knocked some crud loose from the gas tank and clogged up your fuel filter...
Rod.
Old Mar 20, 2007 | 01:06 PM
14922zx's Avatar
Unhappy help
well i tryed to make it to the fueling station,it statred off fair, but slowly stoped, it would only do 4mph,nothing above idle,i put 5 gal. of fuel in and tryed to make it back to my toy box,i made it back,it still ildes very good but will not excelarate,it will spit and sputter and stop,restart and it will only move in first gear without stoping,i did notice at ilde when i turned on the head lights the rpm's droped about 150 or so?? what do you think guys?14922zx PS--could it be a cloged catalytic converter??
Old Mar 20, 2007 | 01:51 PM
try rods idear with the fuel filter, sounds like a good one if you ran cleaning crap through your fuel system, or ran the tank empty you will suck up crud and clogged your new filter.
Old Mar 20, 2007 | 02:18 PM
thxone's Avatar
I know I had a similar problem...car started and idled fine but when I drove it she would only go real slow and bucked and acted a fool....I had a waded up paper towel in in front of my TB...right in the mouth of it. I would imagine anything in the air intake would cause the same problem...could have sucked a plastic bag into the air filter or maybe a bird, cat, dog, horse....
Old Mar 20, 2007 | 03:09 PM
14922zx's Avatar
help
thanks,i am not a docter,but i will have a look ,,what the hell,could be a damn alian,14922zx
Old Mar 20, 2007 | 04:06 PM
skittle's Avatar
Taste My Rainbow
Could Ahve Also Sucked Up A Streat Bum Those Guys Always Get Stuck In My Intake When They Are Asking For Money
Old Mar 20, 2007 | 05:11 PM
14922zx's Avatar
Talking help
i looked in the air duct and it was sucking just fine,i have tryed everything i know to do,idles good, will not idle up without all the crap,is getting fuel and air in but i can't tell about the catalytic cov. how do you check that? 14922zx
Old Apr 10, 2007 | 02:41 AM
BigEkak1941's Avatar
I had a similiar problem a while back. Check the screws on the Air Flow Meter because if they are loose it will not work properly. After tightning the screws the car ran great. Good Luck
Old Apr 10, 2007 | 04:50 AM
naviathan's Avatar
I see you have one of those Honda intakes that could double as a tunnel for AmTrak.
I would check all your connections. Pull your plugs and check the color/coating on them. Have someone sit by the rear passengers wheel and feel the pump while you try to rev it (feel if it's bogigng down or dropping out). Pull the inlet line on the pump and check the little cone filter inside (yes inside) the pump inlet (sometimes it gets stuck in the fuel line). Get a cheapo fuel pressure check set. I bought one from Harbor Freight, it works great and comes with extra hose to hook it all up with. You should have between 24 (min) and 38 (max) psi. Get a vacuum gauge and check the draw at idle. Should be around 18-22Hg. Report your findings back when you get them and we'll take this further.
Old Apr 10, 2007 | 06:00 AM
14922zx's Avatar
Talking Please Help-
I had the car towed to a zx machanic and he ran every check under the sun, and came up with it must be the distributor, so he put a rebuilt one on and that fixed the problem. It runs great, the bill was a pain in *** 527.00 for all the testing. I guess, that it is the last time he will work on my cars, about 200.00 for the distributor, and 300.00 for labor...live and learn,
Thanks guys - 14922ZX
P.S. Hell, I can trial and error until I figure it out, for that kind of money!
Old Apr 10, 2007 | 06:34 AM
naviathan's Avatar
That's usually how it works. THe labor costs more than the parts. I never thought about the distributer. I guess if the bearing is worn bad enough in the shaft it could do that. Did you look and make sure he put a new dist in there? Some places will tell you they've replaced a part when it was really a simple fix.
Old Apr 10, 2007 | 01:08 PM
14922zx's Avatar
Talking
well, he replaced the dist.but ,it was just another one, was not new,he said re-built, he also said he cracked the thermostat housing,and he fixed that at his cost,i do not know why he would that, ,do you??,14922zx
Old Apr 11, 2007 | 07:18 PM
duckyz's Avatar
Cracked the thermostat housing? What the hell did he do? ...nevermind, I probably don't want to know.
