Need Specs
If it was one or two questions. I'd be fine with search. But I'm mobile. So.
Injectors-hi or low? Injector Flow Rate? Fuel Gauge-280zx-ohm rating for new sender?(aftermarket fuel cell) Fuel Gauge-280z,s30-ohm rating if diff then zx(I'm doing both cars) What MSD will work with 280ZX(I want the SCI, but will it work? What MSD will work for a duel webber carbed S30? With 280zx dizzy Or Any aftermarket Ignition system from Accel or what ever. I've seen elec water pumps on these engines. Where can I get them. And where the hell can I get a freakin dry sump oil pump. |
I don't have the answer for all those... but here's what I do have:
Injectors are low impedance. Non-turbos: ~180cc Turbos: ~259cc I don't know anything about the SCI, but I'm sure you could find the specs / compatibility here: http://www.msdignition.com/sci_6.htm I'm using the Mallory 6AL (I think the MSD 6AL is the same thing) & it works great. MSA sells electric water pumps. and www.summitracing.com has a ton of dry sump oil pumps. |
i think 2.7 ohm
Thanks ya'll. The dry sump is a option if I have enough buget left. I should be geting my mock up 2+2 donor car this weekend. Then I get to start the new rear section. I need a Del-Sol window, tracks, and motor. Now I get to order my fuel cell. And sender. Still debateing on ing system. I like the 6al. But the MSD SCI is more ricy, I hate that. But our engines are in the ricer catagory. There's a FireBall and Accel ing's I like also. I can't decide on fuel pumps. All the EFI ones I see are for 800+hp
ok, for a drysump system you also need a custom oil pan, lines, the pump, pulleys to drive the pump and to have your block/head drilled and tapped to use the lines, unless you want to go custom and use the stock oil cooler block, then just tap into one of the ports not being used and pressurize it using the stock oil galleys.... |
| All times are GMT -7. The time now is 05:05 AM. |
