Need some sources
Need some sources
Ok i decided on cold days when im not in the garage i can put my head on and all that since the engine is in the house...i got my ARP head studs from summit since they are 100$ cheaper then zcarparts...
I need to get a 2mm steel headgasket...I hear people talking about HKS steel ones but i googled with little results...zcarparts.com has them but i dont know if they are stock or if they have diff sizes (i have .020 overbore..)....
any ideas?
any ideas?
Did you try contacting HKS USA? www.hksusa.com . I'm sure you wont find any info on their site but if you shoot them an email or give them a call they might be able to help you.
thanks...so thats one option...but i might have some other problems yet ....seems they shaved my head way more then i freaking wanted to...
seems that if i put a 2mm gasket on..THEN will my compression be close to stock setup with n42 head and dished pistons which is about 8.38:1...and to me this is a little bit on the high side for a turbo...
i said check the head...and do not shave anything when i first called them...
they callled me back and said...the head is warped...we will straighten it and shave off .010" to clean up...i said ok 10 isnt bad at all ....well its .080" off the stock size...i dont know what they did i wasnt there when they did it...i hate this hick town!!!! sorry im kinda enraged...
edit: i also told them that this was going to be a turbo application...so i dont want my compression to increase!!! ...ahh i bet they never seen an import engine before...v8 munching bastards!!
ok i will try the local nissan dealer...im sure they will have it...they always have it and its always "oh its the last one in the whole canada, its in toronto but im sure i can get it for you" talk about BS'ing to bring your service reputation up...
ok thanks...i went there a few times...hes all amazed i have a 280zx still drivable in saskatchewan...and hes even more amazed at my brothers 300TT....ill go tomorrow and see...thanks again..
Originally Posted by Lost Vegaz
8.38 to 1. That does not seem high to me. Most stock turbo engines, are 8.5 to 1. And from looking at the blocks, they look incrediblly beefy. Am I missing something.
yup its a big increase in compression from stock to what i have now...but ill make it work..ill let my megasquirt dump buckets of fuel in that chamber and ill retard the timing more... and a good intercooler i think ill be fine for now at least...If i get this thing driveable with a turbo on it boosting 10psi ill be happy...ill consider diff head and more boost ETC later down the road
here is a good read on high CR that very knowledgable people discussed...
http://forums.hybridz.org/showthread...=high+CR+turbo
You also gotta remember that people are turbo and supercharging everything. Even cars with rediculously high CR's like the S2K. Granted they're very limited in the amount of boost they can run with those CR's but it's definitely doable.
but then you gotta look at how much technology has increased in engine and head design, pistons cranks rods etc over the last 25 years....but still im looking at a positive side to this thing...
and yeah my Nissan dealer doesnt have a 2mm steel headgasket...
I can barely afford 91. I couldn't imagine having to fill up with 116
Back when gas was just over a dollar there was a Chevron near my house that had some 100+ octance fuel and even then it was running a few bucks a gallon. I don't even want to know what it's like now. (now that I put that I'm sure somebody is going to post how much it is
I lost one motor that way
