my engine is ticking like a time bomb
Old May 3, 2006 | 04:26 AM
war_ali's Avatar
I'm sure this is bad as bad but I just put my car up for sale and this is what I get for it.
My car is pinging/ticking horribly when i put straight on the engine (accelerate) or rev it up high.
How fatal is this? :'(
This recording is from just above the engine bay (view in quicktime)
http://mcgrathkerr.customer.netspace...ding%20(3).amr
anyone know what could be wrong with it? just as i want to turn the car into a plane ticket..
Old May 3, 2006 | 06:06 AM
naviathan's Avatar
Sounds like valve train noise. Have you done a valve adjustment recently? I'd start with that. It doesn't sound horribly bad. The L28's are typically very noisy. Reference: http://www.atlanticz.ca/zclub/techtips/engine.htm
Old May 3, 2006 | 07:30 AM
Pinging is usually a fuel problem.... as in running too lean.
I don't have a program that can play .amr files. You have a .wav or mp3?
Old May 3, 2006 | 07:45 AM
naviathan's Avatar
If you have quicktime it will play the amr file.
Old May 5, 2006 | 02:17 AM
war_ali's Avatar
hmn thanks for the answeres... do you think i would be doing much damage to the engine by driving it whilst it does this?
ive had the suggestions of broken head seal and stuff? ahh i dno.
im hopeless with this stuff
Old May 5, 2006 | 05:01 AM
naviathan's Avatar
I wouldn't let it go on for too long.
Old May 8, 2006 | 09:47 PM
duckyz's Avatar
Check the oil level before ripping anything apart.
Old May 9, 2006 | 08:01 AM
oil? whas that?
Old May 9, 2006 | 05:35 PM
war_ali's Avatar
well funny u said that... i checked the oil after driving it ( very brielfy!) and there was a bluish oily coloured liquid up to about 3 inches above where the max is on the dipstick. I then waited 5 mins and checked againa nd it was back to normal.
my mech says i have loose tapets and a blown gasket in my extractors "
Old May 9, 2006 | 05:45 PM
jfairladyz's Avatar
Loose tappets would be the cause of noise as you described. Not sure what an extractor gasket is though Never heard that one.
Old May 9, 2006 | 06:45 PM
war_ali's Avatar
i probably heard wrong and made a word up. he said there was a hole somewhere and if i dont fix it the heat from the exhaust could bore a hole into the head of my engine and really kill it
Old May 9, 2006 | 07:35 PM
jfairladyz's Avatar
exhaust manifold gasket maybe? That would let some heat out. It's not going to bore a hole into your head though. He was exaggerating on that one
Old May 9, 2006 | 07:46 PM
i wouldnt trust that guy, just do the valve adjustment thing, youll be fine. my brother had a rocker fall off its pearch and it still ran fine and didnt damage anything
Old May 11, 2006 | 09:24 AM
PooFlinginMonke's Avatar
Is the stud and nut on the rearmost part of the exhaust manifold still there?
Old May 15, 2006 | 11:17 PM
war_ali's Avatar
I dont know. I got a mech to check my tapets but he said they were tighter than insert some rude sexist comment here.
when i trottle i hear a small click at the front end (near the air intake) of the engine. I have to look into that.. but i dont know if that can have some kind of connection to my engines ticking. Is it possible to have a broken seal or something? im hoping its not fatal... my car just keeps cutting my heart
Old May 16, 2006 | 05:26 PM
jfairladyz's Avatar
check to make sure nothing is interfereing with the drive belts. That may be your clicking at the front of the engine.
theatriks
Oct 1, 2013 10:05 AM
dankfrye@charte
Nov 8, 2011 06:59 PM
scorpionp54
Mar 10, 2009 06:33 PM
TheeZ
May 17, 2003 01:00 AM
Dark_Ryder
Dec 18, 2001 01:08 PM
