MSA intake help
Old Aug 29, 2004 | 12:45 PM
Blue280zxTurbo's Avatar
MSA intake help
I just bought an MSA cold air intake. I've been trying to install it for hours, but it just won't fit. It is so aggravating. Does any modification need to be done for it to fit? Or, should I just send it back to MSA, and make my own?
Old Aug 30, 2004 | 07:44 AM
I had to modify the metal tab to bolt onto the radiator support. I think it was too long. That's pretty stupid that they charge so much for a small piece of powdercoated metal and it isn't even made to fit perfectly.
Old Aug 30, 2004 | 08:09 PM
hellzbellz83t's Avatar
send it back and make your own--you can do it for under $20 (excluding filter) with PVC and paint it to look good--that MSA thing is completely obsurd and no, none of them fit right
-Kel
Old Aug 30, 2004 | 09:02 PM
Skully's Avatar
yyah hit the home depot like i did and get some tuping...
why would they make it if it dont fit?!!??!?!
Old Aug 30, 2004 | 10:14 PM
BgMJon's Avatar
I agree, but go with metal tubing, it would suck if the pvc would melt and send toxic fumes into the car.
Old Sep 17, 2004 | 09:55 AM
cm3's Avatar
cm3
yeah I went to Home Depot and got some 3" aluminum tubing that swivels to make a 90 degree bend. when u put on the cone filter it will probably make the tubing swivel down since the contact on the swivel isn't strong. so what I did was to fill in the groove where it would swivel too much with some titanium epoxy so that it would sit straight out in front of the radiator. worked well. doesnt look good but works.
Old Sep 20, 2004 | 06:49 PM
Melting??
The problem with the bendable tubing as the texture on the inside does allow for smooth airflow. What's the point of honing the intake and throttle body if the intake pipe is not smooth? I've had the painted PVC on mine for about 2 years and had no trouble with melting. If you do it and it melts, you've got other problems to deal with.
-Kel
Old Sep 21, 2004 | 08:11 AM
Your K&N filter element will melt before PVC plastic does! Its not that hot up there... just don't go and make yourself some headers from PVC water pipe!
PVC or PCV(?) pipe is very strong stuff. Someone actually used it for a turbo engine to run to and front the intercooler. No melting or breaking yet.
Old Sep 22, 2004 | 12:27 AM
Las VegaZ's Avatar
Pvc for intake plumbing? LOL LOL And I thought I was the only one who did f-cked up things. No offense to who ever did that
dhp123166
Jul 22, 2009 12:12 PM
dag88
Apr 14, 2009 07:27 PM
CWHammer
Feb 21, 2008 09:43 PM
280ZX_AV8R
Jun 17, 2005 06:47 PM
thomas schuchat
Apr 17, 2003 11:26 AM
