more questions
Old Nov 19, 2008 | 04:56 PM
theplasticdr's Avatar
more questions
i have a 83 280ZX non turbo 5 speed. what rear end does it have R200 or R180, or how can i tell ? does it have the round or square port exhaust? and last on the thermostat housing is a electrical plug. the plug has another plug in the harness,where does the other one go ?
Thanks you guys and this site is keeping my Z on the road.
Old Nov 19, 2008 | 05:16 PM
#1... R200 (search for "R200" and you'll find LOTS of info)
#2... Round ports
#3... The other what?
#4... Have you bought a Haynes manual yet?
Old Nov 19, 2008 | 06:22 PM
#1 that what i needed to know
#2 thanks
#3 the second plug in the wiring harness. one goes to the thermostat housing, the other plug is not hooked to anything.
#4 yes. that is the first place i look for answers to my questions. it doesn't go into detail about the wiring.
Old Nov 19, 2008 | 06:28 PM
Haynes page 172 for differential info. Page 103 points out the two thermostat housing sensors (thermotime & coolant temp).
Which sensor are you talking about? Is it a single wire plug? Two wire plug? What color is / are the wires?
Pics help.
Old Nov 19, 2008 | 06:58 PM
it's dark now and my digital camera doesn't make good low light pics.
i can't tell if it's the thermotime switch or the water temp sensor.it's a 2 wire plug.the one below the thermostat is hooked up the other is dangling.
i checked page 103, just can't tell the exact location of the 2 sensors.
i will check the color of the wires in the daylight.
on page 172 it doesn't list the 83. also i don't know if it's GL or a Deluxe model.
will my vin # tell me which model i have?
Old Nov 19, 2008 | 07:03 PM
All 82 & 83 n/a's are the same: GL
And it sounds like it's the thermotime switch. Does your temp gauge still work?
Old Nov 20, 2008 | 03:21 PM
yes the temp gauge works.the one that is hooked up(below the rad. hose, on the thermostat housing) wire color is one green and one white.the plug that is dangling wires are blue with a white stripe and blue with a yellow stripe.???
Bdan57
Feb 5, 2010 12:42 PM
81-280zxnt
Nov 23, 2009 01:24 PM
81-280zxnt
Oct 20, 2009 12:02 PM
SandW
Oct 11, 2006 08:08 AM
pearly whites
Aug 18, 2004 06:20 PM
