MegaSquirt real world 280ZX NA 1983
Hello, I have a like new 280ZX with 64000 miles on it. Been stored all it's life. When I bought it the owner said it had all kinds of electrical problems. Although no one ever mess with it.
I fixed the fuel pump relay and found the only way to get all 6 injectors to fire was to supply my own ground to the ECU. That worked for a few weeks. Until last night the transistors in the ECU that fire the injectors went up in smoke. This is the 3rd ECU. I'm done with trying to fix the 30 year old electronics in this car. I figure there's a bunch of bad wires in the harness that were probably screwed up when it was built. My question is has anyone actually used a system like MegaSquirt in a daily driver car. A car you'd drive 300 miles from home with your family. Not just a weekend fun to play with car. I have read many post on a few forums about MegaSquirt but have yet to see any long term reports. Most post I find are concerning the use of MegaSquirt in a turbo car also. Money is not a problem given a new car cost $20-30K. So spending some cash on a classic to drive all summer is worth it. Any feedback from ppl who have actually converted a 280 NA? |
pm fricfrac he has a setup that allows you to just plug and play megasquirt then just gotta do some tuning. i would daily megasquirt without thinking. the fuel mileage is better too. i was doing to mine but i was doing some funky stuff and now i have to get it working. mine is also an n/a
I installed and ran MS3 in my turbo car but there is no reason you can't run it in an NA. I would recomend getting the turbo dizzy and oil pump spindle so you can use the optical encoder wheel in the dizzy for your CAS. Everything else is pretty straight forward it can seem daunting at first. I ran mine as a daily driver and it pulled hard - much improved over the stock system. I'll be running MS on all my older cars with EFI...
This is my current project - converting an originally carbed from the factory engine to EFI and turbo charged :) https://www.zdriver.com/forums/other...i-build-36313/ |
Originally Posted by SHADY280
(Post 324782)
BTW for now I'm just going to do fuel only. At least until I get it all figured out. Thanks |
its not running it currently, i decided to use a mallory dizzy and for some lovely reason i cant rpm to the ecu. wish it was cause i could sure use the extra power and improved mileage.
MSnS
Have run my 1979 280ZXR (n/a) on MSnS for about two years. If I had thought it out before purchase, I would have bought one of the modified stock brains that are available. That would have been a much easier install and a whole lot less modifications to the car!! And the performance for a daily driver would have been about the same as the MS.
The upgrade to a turbo dizzy is an absolute! The wideband O2 sensor seems to die on a regular basis which causes tuning problems because of the difference in characteristics. (aside: a heat shield for the O2 sensor is an absolute!) Flow rates of your injectors is another sticky point. Also beware of after market fuel pressure regulators...n/a's need one that increases with vacuum, turbo's have one that increases with pressure. Attaching a copy of my tune |
(Post 324948)
Originally Posted by ZXR616
(Post 328681)
