ZDriver.com
-   -   Maxima head (https://www.zdriver.com/forums/280zx-performance-technical-79/maxima-head-9410/)
y2ktranny Jun 3, 2004 11:30 AM
Maxima head
What's the deal with this? Is it a direct bolt on or does it require lots of custom work. Someone give me the skinny on this. :confused:
Bleach Jun 3, 2004 03:05 PM
The Maxima head has higher compression. The Maxima uses the L24. The block has a short stroke and dished pistons so the head has very small chambers to keep compression up. When bolted onto an L28 it will make for a higher compression engine.
The Maxima head has smaller valves like a 240Z head so it is not good for high rpm performance right off the car. I suppose it is comparable to the E31 240Z head.
FastZ Jun 4, 2004 05:28 PM
Do you know the casting number off the maxima head? Is it the n47?
yomammaZ Jun 4, 2004 10:06 PM
What's the deal with the N47 head? Is it pretty good?
FastZ Jun 5, 2004 09:41 AM
I believe when put on with flat top pistons it will raise the compression to 10.1. We just did it on my friends 240 with a 83 lower block with stock internals. Made it a little bit faster.
Bleach Jun 7, 2004 08:42 AM
The earlier 280Z heads will give you higher compression but with an open chamber design. Its a toss-up as to weather they are better overall for performance. If you're against head shaving then its one of only a couple ways to get higher compression.
