low fuel pressure
Old Nov 22, 2011 | 07:42 PM
Lupe's Avatar
low fuel pressure
ok so not so long ago i found out my fressure drops to about 8 psi at higher rpms so i decided to clean my tank cuz it was kinda dirty and changed the fuel filter and tried it again and still nothing is there annything else i should check? it started when i left it parked for about a month and then decided to start driving it again thanks in advance
Old Nov 22, 2011 | 08:29 PM
Fuel pressure regulator.
Old Nov 22, 2011 | 11:18 PM
Lupe's Avatar
I changed one over from my 81 and still bogs way down and pops from runing so lean
Old Nov 25, 2011 | 07:34 PM
DId you blow out the lines and the fuel rail? What if something fouled the regulator and is still in the system. When you said you cleaned the tank did you coat it? Make sure the injectors aren't fouled either. Sounds like there is a blockage between your fuel pump and your gauge. Are you getting full pressure at the pump?
Old Nov 26, 2011 | 05:38 PM
Lupe's Avatar
ui Blew them out whit compresed air ill check how much pressure i get in the back tonight and i didnt get it coated it was just dirty from old gas
Old Nov 30, 2011 | 08:15 PM
Lupe's Avatar
I Checked The pressure At The Outlet on The Fuel Pump And Still Drop So Its Probably Just That My Pump Is Clogged Or Weak
masterhufflpuff
Mar 31, 2015 09:57 PM
hardenstine
Jul 11, 2010 08:28 AM
NewZMan
Jan 14, 2008 07:28 PM
