L28 bored to a 3.0L
Old 04-26-2011, 12:01 PM
  #51
Intrawebz Wizard
BlueKitsune's Avatar
If it was me, I would get a P90 head, deck it about .080 install the 280Z valves (which are .080 longer) Shim up the towers and springs and drop that on an engine with flattops.
That way you have a high CR, A high flowing head and a head that helps reduce pinging buy quenching the air/fuel mix into the spark plug
BlueKitsune is offline
Old 04-26-2011, 12:22 PM
  #52
Originally Posted by 81SacUti280zx
so from what i've been reading since i have flat tops in my block its a california z. is this correct? because i've read a couple different forums that have said n47 head is better than the p79 head for cr. im so confused on which is the "best" way to go for the most efficient street daily driver with med. power. i also been told the p79 head has way better flow than a n47 but the n47 will give me a higher cr with the flat tops.
From another recent thread:
https://www.zdriver.com/forums/240z-260z-280z-s30-forums-9/im-newb-here-would-appreciate-some-help-my-build-32481/
NismoPick is offline
Old 04-26-2011, 03:49 PM
  #53
81SacUti280zx's Avatar
Ok. So i spoke to a well known machine shop around here and found that the old timer there knows these heads very well. So i guess i need to know for sure... .070" shave off the head...and .007" cam tower shims? port and polish(mild) and he has a flow bench and will work with me because i work here at toyota in carson and we send him all the work so he is going to cut me a huge break. what else do i need to tell him exactly do get this done?
81SacUti280zx is offline
Old 04-27-2011, 08:24 PM
  #54
GTH
GTH's Avatar
doh, i kinda knew my car was going to cost a bit to get it where i want it but 7k. and just into the motor. ouch. this thread is depressing
GTH is offline
Old 04-27-2011, 09:12 PM
  #55
You can build a healthy L28ET for less than $7k... it's just that some people don't like / want turbo setups...
Old 04-27-2011, 09:25 PM
  #56
ya 7k you could do a rb25dett swap with 6spd trans and all wheel drive set up...make it awesome for 7k. but idk lol..
Old 04-27-2011, 09:28 PM
  #57
I guarantee you couldn't make a 280zx awd in that $7k budget. You'd need the entire front clip, and do a lot of fab work.
Old 04-27-2011, 09:55 PM
  #58
West Coast!
tonsoffun300zx's Avatar
excuse me sir but i begg to differ here is proof: http://kalecoauto.com/index.php?main...id=38:biggrin:
tonsoffun300zx is offline
Old 04-27-2011, 10:26 PM
  #59
Lol - a step down from the wind up elastic band all wheel drive conversion. Lol - try not to turn after installing this kit
FricFrac is offline
Old 04-27-2011, 10:32 PM
  #60
Under $7k is easy if you had a vg or RB motor. Just swap the rear section of the trans with an AWD RB trans, make driveshafts, convert to the lower half of an RB oil pan with the diff in it, convert to R32 front spindles and have the front stub aces shortened. It's easily done for under $7k if you do the fab work yourself and source parts and have a reliable machinist. Hell most 240sx guys do it for less then $3k.
hoov100 is offline
Old 04-28-2011, 07:32 AM
  #61
Show me where you can source all that for less than $3k... Otherwise I stand by my statement.
Old 04-28-2011, 10:41 AM
  #62
Buy this, sell everything you don't need (or just do an RB swap) and I'm sure you would recover about half of the cost.
http://cgi.ebay.com/ebaymotors/Skyli...Q5fAccessories
hoov100 is offline
Old 04-28-2011, 10:53 AM
  #63
Alright, I semi-retract my statement. It CAN be done... but I doubt many could pull it off.
Old 04-28-2011, 11:08 AM
  #64
LOL ok..so back to the topic at hand....it would be to my benefit to get my orig p79 head machined and try to find cheap replacement parts i.e.(valves, springs, keepers,seals, etc.)?
Old 04-28-2011, 09:22 PM
  #65
Get a junker. I just gave my P79 away. Do you have a local Datsun club?
FricFrac is offline
Old 04-29-2011, 06:12 PM
  #66
get a junker head? i have a spare head off my 83 2+2
Old 04-29-2011, 08:31 PM
  #67
So... why aren't you using that to send to the machine shop?
Old 04-30-2011, 09:42 PM
  #68
Uh...
FricFrac is offline
Old 05-01-2011, 09:51 AM
  #69
well i figure my orig head is already taken apart and stripped so...i mean the exhaust bolt holes and such are gonna be a pain but...we'll see
Old 05-01-2011, 12:05 PM
  #70
What good is a parts car if you aren't going to use it for parts?
Old 05-01-2011, 01:25 PM
  #71
i see where your coming from but finding the time to pull the head and everything off the parts z is the problem. the parts z is at my moms and that is about 45min drive. i have a very limited supply of tools...no air and not to mention i would be working in the dirt and wind the enitre time.
Old 05-04-2013, 11:00 AM
  #72
strokerturbo's Avatar
can ka24dett pistons be used in a stroker turbo l28
strokerturbo is offline
Old 05-04-2013, 01:12 PM
  #73
Zdon's Avatar
Rebuild advise
OK. thank you. i might be selling my xb today so i will have about 3k extra in pocket. hopefully he isnt too expensive to do my head and shipping isnt a killer. I still need to buy 2 fenders and poss. a rr quater panel. rust is a killer lol. if i have him shave .070 off i can get a kit from msa for the shims..would that be just as good? and if i do shave the head and shim it will that be all i need to do and just bolt everythig back up and run it?
Do you have flat top pistons or dished ? Flat top pistons with a bore between .040 and .070 over and i suggest using an N47 cylinder head with flat top pistons or if you run a P79 head make sure you use the early cylinder head valves which are longer and shim the cam towers. In my opinion the N42 cylinder head will give you the type of performance you're looking for as it has a better flow than N47 and P79 heads. If you can afford porting and polishing the intake and exhaust ports the better the performance with the camshaft you mentioned. Cheers !
Zdon is offline
BlueKitsune
10-15-2010 11:05 AM
BlueKitsune
09-06-2010 10:05 PM
lww
05-04-2006 10:45 AM
s/cL3.0
11-14-2005 07:54 PM
Zrolimit
08-28-2005 07:13 AM
Quick Reply: L28 bored to a 3.0L
